Convert M21 into an M20?
Old Oct 15, 2001 | 09:36 PM
Flareside's Avatar
Flareside
Default Convert M21 into an M20?
My muncie will need a rebuild sometime in the future, and I'd like to convert it to a wide-ratio M20 as the same time. Doable? Economical?
-Joe
Old Oct 15, 2001 | 09:40 PM
PRNDL's Avatar
PRNDL
Default Re: Convert M21 into an M20? (Flareside)
There's a new one! (at least for me!) You would just swap out a few gears, right? Having no real clue, I will be interested to see the responses you get. The obvious alternative will be to swap your trans with someone who wants the M21 but has an M20. What is your rear end ratio? MJ
Old Oct 15, 2001 | 09:47 PM
GTR1999's Avatar
GTR1999
you can call Reed's classic 4-speeds 203-265-6888 in Wallingford CT. Dave will take care of you.
Gary
Old Oct 15, 2001 | 09:49 PM
Flareside's Avatar
Flareside
Default Re: Convert M21 into an M20? (MNJack)
Mark, I have the 3:55 rear. The M21 gears, if you ask me, are a little too close together for normal street driving. Hopefully, I can just change a few gears like you suggested. Somehow, I doubt it's that simple...
I don't want to swap the trans, since it's the original numbers matching trans for the car. I have thought about buying a used M20, then putting all the parts into my trans housing. We'll see.
-Joe
Old Oct 15, 2001 | 10:37 PM
Gordonm's Avatar
Gordonm
Joe this is going to be costly. I replaced just 3rd gear and it cost me about 150 for a used gear. To replace all 4 gears and the countershaft would be quite expensive. I have a M20 in mine with the 4.11. I like the low 1st gear and when I had the 3.55 rear it worked very well to.
Old Oct 15, 2001 | 11:50 PM
FINWOLF's Avatar
FINWOLF
Joe this may help you
http://www.muncie4speed.com/
Old Oct 16, 2001 | 12:57 AM
74vetteman's Avatar
74vetteman
I think all you have to do is change the cluster gear. If I remember correctly, m-20's and m-21's share the same main shaft gears, however I could be wrong. Go to http://www.5speeds.com. They sell individual gears or complete sets for all muncies at quite reasonable prices. The owner (Paul) is a transmission guru and can answer questions personally via the phone number available on his web site. I've dealt with him and recommend him highly!
[Modified by 74vetteman, 12:19 AM 10/16/2001]
Old Oct 16, 2001 | 03:49 AM
oger's Avatar
oger
Default Re: Convert M21 into an M20? (74vetteman)
You need to change the cluster and input everything else is the same.
Old Oct 16, 2001 | 10:11 AM
Flareside's Avatar
Flareside
Default Re: Convert M21 into an M20? (Gordonm)
Gordon, it looks like I don't have to replace everything. Only the input shaft and the cluster, which run around $350. Sounds like a good winter project.
Thanks everyone!
-Joe
Old Oct 16, 2001 | 10:16 AM
Flareside's Avatar
Flareside
74vetteman, thanks for the tip! I'm going to buy Paul's rebuild video. His part prices also look pretty good.
-Joe
Old Oct 16, 2001 | 12:54 PM
Detroit Vette's Avatar
Detroit Vette
i have a fresh m-20. zero miles on it. i want a m-21. hmmm? :eek:
Old Oct 16, 2001 | 03:00 PM
paul_64conv's Avatar
paul_64conv
My tranny guy did the swap for free when he rebuilt it. It seems that the close-ratio gears are in more demand. I guess he'll charge the next guy who wants to go to close-ratio. Call around.
Old Oct 16, 2001 | 03:02 PM
paul_64conv
P.S. - I like the wide ratio a lot more. I have 3.36 rear.
Old Oct 16, 2001 | 04:34 PM
Gordonm's Avatar
Gordonm
Default Re: Convert M21 into an M20? (paul_64conv)
Yea I did not have my facts straight. Sounds like a good project. It probably needs a rebuild anyway. why not make it like you want. It is not to hard to do if you have the manual or a video.
To Convert M21 into an M20?
