Amp Gauge
Old Apr 9, 2007 | 10:57 PM
coinwasher's Avatar
coinwasher
Default Amp Gauge
My Amp Gauge is pegging with a small load I have all new wire harnesses and all new gauges, I have checked every connection and every ground at least three times any slight load peggs it out. Did the originals use those little resisters across the terminals?
Old Apr 10, 2007 | 05:03 AM
StickShiftCorvette's Avatar
StickShiftCorvette
There is no resistor accross a C3 amp gage.
It sounds like the large (red I think) wire that runs from you alternator to the starter's main (large battery cable) terminal. That would cause all current to flow through your amp gage, something that it is not designed to handle.
Only a small percentage of current is meant to flow through a C3's amp gage.
Old Apr 10, 2007 | 09:52 AM
coinwasher's Avatar
coinwasher
Man! Free advice is priceless. You made my day, your post jarred my memory as ther was one large non wrapped red wire that I had connected to the power window relay up on the firewall. This wire actually goes to the horn relay on the inner fenderwell next to the steering box. When I relocated it the AMP gauge started working normally. Thanks a million Stickshift, I owe you one.
Old Apr 10, 2007 | 09:36 PM
sandiego21's Avatar
sandiego21
Glad you solved your prob. wondering if I have the same. Can you help. See C3 General - Alternator Overcharging. Summary: Alternator appears fine but gauge reading 15ish. Can it be similiar to yours or do I have a bad gauge? thanks for any help you can give!!!
Old Apr 10, 2007 | 09:48 PM
coinwasher's Avatar
coinwasher
Mine was smoking amp gauges due to an improperly place wire on a harness replacement, there was no 15sh it was peg forty and then smoke.
Old Apr 10, 2007 | 10:22 PM
Big2Bird's Avatar
Big2Bird
You have a voltmeter, not an ammeter.
Old Apr 10, 2007 | 10:57 PM
coinwasher's Avatar
coinwasher
Good point Bird, was your buddies oil pump shaft bushing trashed?
Old Apr 10, 2007 | 11:32 PM
Big2Bird's Avatar
Big2Bird
Cracked. We changed it while we were changing the rear main seal. Went with an aftermarket shaft with steel coupling recommended by Iron Cross.
Old Apr 10, 2007 | 11:37 PM
coinwasher's Avatar
coinwasher
Great choice, I was good of you to help the dude out.
To Amp Gauge
