Looking for temp sensor for 72
Old Apr 10, 2007 | 10:25 AM
KJL's Avatar
KJL
Default Looking for temp sensor for 72
What I am looking for is a sensor that will work with my existing gauge but will fit a smaller 1/4 or 3/8 NPT hole.
I think the stock unit is 1/2" NPT. To damn big for most modern instrument ports. I purchased a smaller unit but it did not work at all. I don't want to get new gauge because I already have to many new gauges strapped to my steering column and no, I don't want to remove the gauge panel to replace to old one. Rather have a rectal exam by the Jolly Green Giant than remove that again.
Old Apr 10, 2007 | 10:50 AM
TedH's Avatar
TedH
what style connector and sender terminal are you wanting to use? Dr Rebuild offers senders for most of the C1/C2/C3 years. I ultimately moved my original temp sender to my intake manifold as my DART cyl heads would accomodate only the smaller sender and I didn't want to mess with trying to find a smaller sender that would work with my old L48's system. Is that an option for you? Most aftermarket intakes have 1/2" NPT holes in the water passages. I removed my thermal sensors (control vacuum) so I used a resulting 1/2" NPT hole in the intake's water passage that leads to the thermostat housing.
Old Apr 10, 2007 | 11:09 AM
KJL's Avatar
KJL
Yes, that is what I am doing now, but I am looking to switch to an intake that does not have one that size. I could overobore it but would prefer not to.
Old Apr 10, 2007 | 12:03 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
do you guys know what gauges are mechanical vs electrical on a 69??? i am wrapping up the install of my 79 engine in the 69 tilt front and i have to get the oil pressure and water temp sending units but i realize i don't know if they are electrical or mechanical. do you know thks bob
Old Apr 10, 2007 | 12:05 PM
markdtn's Avatar
markdtn
With stock heads, just use the stock sensor in the head. I have L98 with aluminum heads and I just used an 82 sending unit (3/8), it reads pretty close in my car. I also think 'Lectric Limited has a 3/8 that will work.
Old Apr 10, 2007 | 12:09 PM
TedH's Avatar
TedH
My 69's oil pressure gauge appears to be fed by the old fashioned method; mechanically via oil in a plastic line running from a brass fitting attached to the rear of the engine just behind the distributor/intake manifold. As for the rest... water and battery get signals via wiring and tach is mechanically driven from the base of the distributor.
Old Apr 10, 2007 | 12:10 PM
pws69's Avatar
pws69
OIL = Mechanical (line to top of block behind distributor)
WATER = Electrical (sensor in Driver side head)
Old Apr 10, 2007 | 12:42 PM
bobs77vet's Avatar
bobs77vet
thks guys i will look to see what wiring and tubing is in the engine bay, perhaps i missed the mechanical tubing. thks bob
To Looking for temp sensor for 72
