Need Shift Indicator Lamp Socket
Old Oct 15, 2001 | 11:58 PM
Edzred72's Avatar
Edzred72
Default Need Shift Indicator Lamp Socket
GEEEZ.. :mad I can't locate one anywhere :crazy: Seems the previous owner took it out and left the cut wires taped up :smash: The lamp socket I seek illuminates the auto trans shift indicator in my '77. Any suggestions?? : Thanks cheers: :seeya :seeya :seeya
Old Oct 16, 2001 | 12:17 PM
Edzred72's Avatar
Edzred72
Default Re: Need Shift Indicator Lamp Socket (Silvr77)
Geee..was it something I said? :confused: Nobody has any advise :confused: :cheers:
Old Oct 16, 2001 | 12:34 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Yea take a bath will ya? :D:D :lol: :cheers:
I would try to find one at a Corvette junkyard or something. Or maybe there is a simular part in other GM cars?
Old Oct 16, 2001 | 01:06 PM
noxqsz's Avatar
noxqsz
Silvr;
I need exactly the same part for my '73. Actually, the post that suggested a Corvette salvager or using a socket from another GM vehicle is probably our best bet. According to my AIM, the wire, connector, and socket are a separate part and have their own part number. For my '73, it's 6901012. I'm in the process of trying to locate that part, or at least get a spec for the socket. There are also lots of wrecking yards in the area where I live and I'm going to see if I can run one down that way. If I can find an extra, I'll let you know.
Old Oct 16, 2001 | 05:36 PM
Edzred72's Avatar
Edzred72
Default Re: Need Shift Indicator Lamp Socket (noxqsz)
Thanks a ton nox. Keep yer eyes peeled, as I will do the same for you. Their aren't too many grave yards in northern Illinois, and the ones that are here, are picked clean of older parts. I'll be lookin for "US" both :cheers: :seeya :seeya
Old Oct 16, 2001 | 05:45 PM
chevluvr's Avatar
chevluvr
St. Jude Contributor
I am in the same boat with you guys. Can't locate through normal channels. I went to NAPA and the real non vehicle counter help had no clue. If you guys locate any extra ones please advise. I will do also.
Good Luck
[Modified by chevluvr, 3:46 PM 10/16/2001]
Old Oct 17, 2001 | 05:53 PM
Edzred72's Avatar
Edzred72
Default Re: Need Shift Indicator Lamp Socket (chevluvr)
Chevluvr:
Email me and I will give you some info. :cheers: :seeya :seeya :seeya
To Need Shift Indicator Lamp Socket
