Big Block timing
Old Apr 10, 2007 | 11:10 PM
coinwasher's Avatar
coinwasher
Default Big Block timing
I have a 427 stroked to 454 with an L-88 cam and pointless ignition. The engine only has about two hour run time. I had the timing set at 8 degrees and the engine sounded OK. Today I bumped the timing up to 11 degrees and the motor sounds much better than it did at 8 degrees and there seems to be no pinging when I drove it. The mallory distributor has no vacum advance and the cam was not degreed. Is it OK to run it at 11 degrees?
Old Apr 10, 2007 | 11:26 PM
noonie's Avatar
noonie
See the sticky on timing at the top of the page.
Old Apr 10, 2007 | 11:35 PM
coinwasher's Avatar
coinwasher
What sticky?
Old Apr 10, 2007 | 11:45 PM
Big2Bird's Avatar
Big2Bird
http://forums.corvetteforum.com/show....php?t=1430339
Old Apr 11, 2007 | 01:10 AM
Ironcross's Avatar
Ironcross
The distributor probably has 24 degrees built into it. If thats correct your at 35 total. You may even be able to go a degree or more further. As you advance it the idle will go up, dont worry about that. Merely turn the idle back to around 850 by the carb idle screw.
Old Apr 11, 2007 | 09:33 AM
lars's Avatar
lars
With that cam and no vacuum advance, you want to run initial timing up around 18 degrees and shorten the centrifugal advance curve down to about 18 so you get max total advance of 36. You can even go as high as 22-24 degrees initial as long as you shorten the curve enough to limit the total to 36. 11 degrees initial is not by far enough.
Old Apr 11, 2007 | 10:43 PM
coinwasher's Avatar
coinwasher
Thanks I will set it up this weekend when I get home, sort of explains the loud exaust.
Old Apr 12, 2007 | 01:50 AM
gofastvette's Avatar
gofastvette
36 degrees is a good total lead. Most of the aftermarket Mallory distributors have approximately 24 built into them. 12+24=36. 18-22 initial, may be too much. If you dont know for sure run it up to 3000 and set it at 36. I have run that cam before and it`s a nice one. Use premium gas and you may even give it a few more degrees. Too much lead and it may be hard to start.
To Big Block timing
