ZZ430 Upgrade
Old Apr 11, 2007 | 02:30 AM
Punisher32x's Avatar
Punisher32x
Default ZZ430 Upgrade
Hi, I currently have a 385 fast burn crate motor in my 71' and I was going to install the LT4 hot cam kit to make a ZZ430 clone, My question is to anybody who has performed this upgrade before, what parts are used in the kit because I know some of the parts in the hot cam kit are already in the 385 fast burn motor?
Thanks ahead of time for your help
Old Apr 11, 2007 | 06:18 AM
Fevre's Avatar
Fevre
Fastburns already have LT4 valve springs so you should be able to drop in the hot cam no problem. With 1.5 rockers you get about .495 lift, with 1.6 rockers you get .525 lift.
Old Apr 11, 2007 | 06:38 AM
jerome1979's Avatar
jerome1979
Take a hot cam kit!
only spring are still on 385 FB all other parts are different (camshaft, rocker)
Part#1248002
like this:
http://store.summitracing.com/partde...2&autoview=sku
Old Apr 18, 2007 | 04:00 PM
Punisher32x
Hi, one more question for everybody. I am currently running synthetic oil (Mobil 1 5W 30), and I was told once I install the LT4 hot cam kit I should change back to regular non-synthetic Mobil 1 10W 30 for a proper cam break in procedure?
Is there any truth to why I should change to non-synthetic?
Thanks a lot everybody who have already responded
Old Apr 18, 2007 | 04:10 PM
1fastC3's Avatar
1fastC3
Get a can of GM EOS break in lube if your really worried and dump it into the oil, or use Shell Rotella T. As for the oil afterwards, just use what youve been using.
-alex
Old Apr 18, 2007 | 04:32 PM
jerome1979's Avatar
jerome1979
http://www.sallee-chevrolet.com/Disc.../653/1300.html
hope this help
Old Apr 18, 2007 | 04:42 PM
DZRick's Avatar
DZRick
Originally Posted by jerome1979
That will help you and I'll add price the out the hotcam and 1:6 rockers of your choosing compare that to the "kit" then decide.
I went with the cam and rockers instead of the kit, it was cheaper. Nice motor too.
Old Apr 18, 2007 | 05:01 PM
Scootin_Z's Avatar
Scootin_Z
I've always been told to use regular oil to break in as well. I don't know...I just do it and then swap to my amsoil.
I did a ZZ430 clone in my Camaro. Great motor for the money! Drove the car on the Hot Rod Power Tour a few years back from Milwaukee to Kissimmee Fla in sweltering heat with the A/C and still got 18 MPG with a 700R4 installed. Motor ran flawlessly.
To ZZ430 Upgrade
