temperature sending unit
Old Apr 12, 2007 | 04:48 PM
Red70vette's Avatar
Red70vette
The Lectric Limited unit is dead on and works well. I did not use sealant or tape and it worked fine. When I removed it I lost less than a quart of fluid nothing a mop can't handle.
Old Apr 12, 2007 | 07:10 PM
Big2Bird's Avatar
Big2Bird
I guess I will bite. "If it was dead on, why did you remove it?"
Old Apr 13, 2007 | 08:25 AM
S489's Avatar
S489
i read it as (assumed) sentence 3, then 1, then 2
there is something wrong with grammer in last sentence too, i'm sure of it!!!!
Old Apr 13, 2007 | 12:11 PM
Lonestar One's Avatar
Lonestar One
Default Temp Sender Problem
Newbie piggy backing alert!
My gauge is reading very low (just above 100 deg.). I have replaced the thermostat and cleaned the sender and connection. I tried grounding the connector for the sender directly to the negative terminal of my battery and could only get a reading of about 225 (not full scale like I thought it would do). I have taken temp reading with a gun all over the engine and radiator and of course get different temps. My questions are:
Where is the best (most idicative) place to get an accurate water temp with a gun?
Should my gauge go full scale if properly grounded & where is the best place to ground?
Can you test a sending unit (boiling water)?
Can you recalibrate the gauge?
Thank you in advance.
Old Apr 13, 2007 | 01:08 PM
KJL's Avatar
KJL
1)Ideally you should take the readings near the sender if you want comparative info.
2)Only getting 225??? what are you expecting?
3)You cannot recal the gauge
4) If you are getting diff readings depending on where you ground, You have a grounding problem. Sounds a bit high but closer to correct than 100+. Check your ground straps going to you engine as well.
Oh, where you do use the gun, make sure that area is shielded from as much air movement from the fan as possible. That alone could drop the temp 50 degrees+.
Old Apr 13, 2007 | 02:12 PM
S489's Avatar
S489
i agree with 1), but i've had trouble getting good readings with a gun and with the sending unit in the head, so in that case shoot the thermostat housing. i was using a $100 gun, a $1000 gun may have worked. when the thermostat is working, engine fully warm, the reading at the housing should be very close to the thermostat setting. then look at your gauge reading. it will be higher, but close.
you can use an ohm meter to check the sensor (out of the car first); i think i saw somehwere on the net ohm values for ambient and boiling. i'm pretty sure that the more resistance, the higher the temp reading on the gauge. old wiring will have more resistance too. i agree with 3) too, you can't recal gauge; you could add resistance, but nobody does, and that also may be the problem. based on this, i think gauge would go full scale when grounded. don't have any notes in front of me, if wrong, someone please correct. thx
Old Apr 13, 2007 | 02:17 PM
Lonestar One
Thanks for the reply. I expected the gauge to go full scale (250) with the gauge grounded directly to the battery. Instead of one mark shy (about 225). I just don't know if it is a bad gauge or temp sender or both. Maybe I'm not getting hot enough to begin with. Doubt it. Thanks again.
Old Apr 13, 2007 | 03:16 PM
S489's Avatar
S489
i agree; it's an old gauge now though
Old Apr 19, 2007 | 02:05 PM
S489's Avatar
S489
reference to NPT threads from ASME B1.20.1:
1.3 Sealing
1.3.1 Where pressure-tight joints are required, it is
intended that taper pipe threads conforming to this
Standard be made up wrench-tight with a sealant.
To prevent galling on certain piping materials such as
stainless steels, the sealant usually contains a lubricant.
1.3.2 Pipe threads designed for pressure-tight
joints that may be used without sealing compounds
(Dryseal Threads) are covered in ANSI B1.20.3 (Inch)
and ANSI Bl.20.4 (Metric Translation).
Old Apr 19, 2007 | 02:16 PM
JPhil's Avatar
JPhil
For the third time in 24 hours......
http://en.wikipedia.org/wiki/National_Pipe_Thread_Form
Old Apr 19, 2007 | 05:30 PM
S489's Avatar
S489
sorry 'bout that JPhil, i looked back in this thread and didn't see where you posted three times.
i posted because i ran across the actual text from the national standard regarding how the NPT threads are to be made specifically with respect to sealing. it is called B1.20.1 and is published by ASME.
it looks like your post references Wikopedia which references the same standard, but does not include the text under the heading 1.3 Sealing. i'm not sure, but i assume we are in agreement on the content.
Old Apr 19, 2007 | 07:14 PM
JPhil's Avatar
JPhil
Nah, it was in the other two temp sender threads! The wikipedia info explains some of the stuff better, including the NPTF "self sealing" threads........
