73' suspension
Old Apr 11, 2007 | 07:44 PM
franksc2's Avatar
franksc2
Default 73' suspension
I have a 73' that i've had for year, and i was wondering if any of you guys know what i can do to improve the ride? right now the car handles a rides extremly bad and is all over the road and feels like there is no suspension at all. what can i do to improve it?
Old Apr 11, 2007 | 07:57 PM
7T1vette's Avatar
7T1vette
Wow! Where to start... Ball joints, idler arm, steering joints/pivots, shock absorbers, steering box, wheel bearings... All, or some, of the list may be your problem in the front end. Then you have trailing arm bushings, wheel bearings and shocks in the back. The tests for all of these would take too long on this thread. My advice is to take it to a reputable alignment service [that works on Corvettes] and pay them to work up a list of suspension needs. It could be as simple as shock absorbers...but likely is not. If your steering components check out OK, you might need an adjustment to your steering box [or a rebuild, if damaged].
Old Apr 11, 2007 | 08:12 PM
franksc2's Avatar
franksc2
Thanks, I plan on replaceing alot of the steering componets, i know when i put p/s fluid in it leaks from about 10 different spots and spews out everywhere when i crank it up. So i'm defenitly going to replace probably most of the steering components. I'll probably start with the shocks first and work my way through. Thanks for the advice and info!!
Old Apr 11, 2007 | 09:53 PM
Crunch-o-Matic's Avatar
Crunch-o-Matic
My 73 was the same when I got it.
I "bit the bullet" and did the following all at once:
1. I bought a complete suspension rebuild kit from vette brakes; 360lb mono spring, 550coils, sway bars, Bilstein shocks, etc.
2. Rebuilt the upper and lower control arms (ball joints, bushings, etc)
3. Rebuilt the power steering assembly; ram, pump, hoses, idler arm, new rag joint, and steering box. If I had it to do over again I would have bought a Steeroids conversion for the steering. I just dont like the old steering system.
4. Rebuilt trailing arms ; new bearings, axles, bushings, e-brake, etc.
5. Rebuilt rear and had gears changed to 3:55s.
6. Had half shafts and drive shaft balanced and installed new u-joints.
That about does it....
Car handles better than new.
Cheers,
Crunch
Old Apr 11, 2007 | 09:54 PM
flynhi's Avatar
flynhi
Start with the safety items first: brakes and steering. Then ball joints and bushings (poly). Then springs, then shocks.
Check Vette Brakes, Zip or Muskegon Brake for package pricing.
This work is not brain surgery - just time consuming and messy. Do it yourself and learn a lot about your Vette while saving $ for the next project.
Old Apr 11, 2007 | 10:25 PM
SEVNT6's Avatar
SEVNT6
All of the above! I made a big improvement in the ride on mine when I put Edelbrock shocks on. They have a valve in them that opens up on bad pavement to give a softer ride. But it's closed on smooth roads to keep things nice and stiff........................
Old Apr 11, 2007 | 10:29 PM
7T1vette's Avatar
7T1vette
All good advice. But when you consider buying components, at least evaluate what you will be doing with the car. If you will be road racing on the weekends, by all means, spend the extra buck$ to get adequate equipment for that kind of use. On the other hand, if normal driving is what you will be doing (and the car was designed to be driven and drag raced), then save a few bucks and just replace the components with OEM or direct replacement parts. Keep in mind that for steering and suspension components, brand DOES make a difference. Quality steering components will pay for themselves by not failing in just a few years. NAPA and GM Parts sell quality stuff; others do too, but it may be a little more difficult to be sure. I would NEVER buy important hardware from a corner auto parts store...they just get too much junk from China and other sources.
Old Apr 11, 2007 | 11:01 PM
franksc2's Avatar
franksc2
thanks for all the advice, you guys have been very helpful
Old Apr 15, 2007 | 12:56 AM
FRSTR90's Avatar
FRSTR90
Not to put you hopes down, but don't expect your car to ride like a cadillac... When you back is like a foot from your differential, you are most likely are going to feel the road...
Old Apr 16, 2007 | 09:33 AM
franksc2's Avatar
franksc2
yes i realize that but i know it should be a little better than it is right now. I can barely keep it on the road.
Old Apr 16, 2007 | 09:48 AM
texbeasr3's Avatar
texbeasr3
Check the steering couping. The rag joint can be worn, and the steering will be sloppy. Look at the coupling stops to see if it moves from one stop to the other. Replace or rebuild.
To 73' suspension
