C.R. Ratio?
Old Apr 12, 2007 | 11:59 AM
CAJUN C4's Avatar
CAJUN C4
Default C.R. Ratio?
What's the stock Comp. Ratio in a 78'?
Old Apr 12, 2007 | 12:09 PM
KJL's Avatar
KJL
It would be safe to say less than 9.0, most likely around 8.5:1
Old Apr 12, 2007 | 12:11 PM
sperkins's Avatar
sperkins
CHW L48 350-cid 185-hp V-8 8.2:1 manual four-barrel carburetor
CLM L48 350-cid 185-hp V-8 8.2:1 automatic four-barrel carburetor
CLR L48 350-cid 175-hp V-8 8.2:1 automatic four-barrel carburetor California
CLS L48 350-cid 175-hp V-8 8.2:1 automatic four-barrel carburetor high-altitude
CMR L82 350-cid 220-hp V-8 8.9:1 manual four-barrel carburetor
CMS L82 350-cid 220-hp V-8 8.9:1 automatic four-barrel carburetor
CUT L48 350-cid 185-hp V-8 8.2:1 automatic four-barrel carburetor
Old Apr 12, 2007 | 12:40 PM
CAJUN C4's Avatar
CAJUN C4
What would be an approx. HP Gain bumping it to 10:0 - 10:5 to 1?
Old Apr 12, 2007 | 12:44 PM
zwede's Avatar
zwede
Rule of thumb for changing from 9:1 to 10:1 is 4%-6% gain.
But with the stock heads & cam it will ping like crazy at that CR.
Old Apr 12, 2007 | 12:52 PM
CAJUN C4's Avatar
CAJUN C4
Gonna run a Comp Cams 268H .Should be fine I would think.Stock Heads though.
Old Apr 12, 2007 | 01:11 PM
sperkins's Avatar
sperkins
How do you plan on increasing compression with the stock heads?
Old Apr 12, 2007 | 01:19 PM
KJL's Avatar
KJL
If you are going to run that cam you need to pick up your CR and flow. Your car run will run like a total dog with no bottom or top end. I put a set of Edelbrock performer RPM heads with 68 cc (I think) chambers and that pick up my CR to about 9.5:1, I install a CC 256 cam and a set of Dynomax headers and my rear wheel HP was 260 hp with 320 ft-lbs Tq. Using a Turbo 400 that would put my engine out put at around 330 hp. Not bad. A far cry from stock. You will gain more from just upgrading to headers for now and save up for some good heads.
Old Apr 12, 2007 | 01:24 PM
CAJUN C4's Avatar
CAJUN C4
With new pistons.
Were sending the engine to Jasper for a complete rebuild.
Old Apr 12, 2007 | 02:22 PM
Little Mouse's Avatar
Little Mouse
with a 76cc, 78 factory head you will have small dome pistons to end
up with 10 to 10.5 comp. you end up with 10.5 and a XE 268 cam
ping city.
Old Apr 12, 2007 | 02:37 PM
CAJUN C4's Avatar
CAJUN C4
ping city.
What do we need to do then? Better heads? Milder cam?
Old Apr 12, 2007 | 03:32 PM
BigBlockk's Avatar
BigBlockk
You need more camshaft not less.
BigBlockk
Later.....
Old Apr 12, 2007 | 03:38 PM
dgruenke's Avatar
dgruenke
You need better heads and a different cam. Is the transmission an auto or 4spd.? If it is an auto, you can only go with so large of a cam without changing the torque converter. Smaller cams limited the CR that you can use.
If you want to run 10-10.5 CR with iron heads, you better be looking at a fairly big cam.
Get some dish pistons, some good 64cc heads, and the XE268 cam will work fine.
Old Apr 12, 2007 | 03:39 PM
dgruenke's Avatar
dgruenke
Duplicate post
Old Apr 12, 2007 | 04:36 PM
Little Mouse
If your going to run old style combustion chamber iron heads
your going to have to be happy with 9.00 to 9.5 comp ratio
it would take a lot of cam to bleed off enough comp for 10.5
to work, way more then your probably willing to run in a street
car and even then a big cam in a 350 you would have soggy
torque down low. 76cc heads are a pain to make any comp.
with and a 3.48 stroke.
To C.R. Ratio?
