81 headers
Old Apr 12, 2007 | 08:20 PM
HO-alts-Rick's Avatar
HO-alts-Rick
Default 81 headers
I have the stock headers on my 81 with the valve thing on the passenger side. Do the make replacements that dont have that or the injection tubes on top?
Old Apr 12, 2007 | 08:24 PM
Big2Bird's Avatar
Big2Bird
Identical without the tubes? No.
Old Apr 12, 2007 | 08:26 PM
HO-alts-Rick
Ok, time to fire up the mig and grinder then. LOL
Old Apr 12, 2007 | 08:28 PM
Big2Bird's Avatar
Big2Bird
Honestly, they are crap. A set of 80 cast iron ram's horns flow better, and won't crack all the time. A known problem.
Old Apr 12, 2007 | 08:34 PM
HO-alts-Rick
Will they bolt right in?
Old Apr 12, 2007 | 09:21 PM
a1sensei's Avatar
a1sensei
Yes, but a good set of ceramic headers is a much better option. God bless, Sensei
Old Apr 12, 2007 | 09:40 PM
kdf1986's Avatar
kdf1986
There is a heat riser/butterfly valve bypass pipe that can be bolted on in the place of the current setup. This is essentially a spacer that bolts on in the place of the current setup.
Check your emission control regulations in your area prior to doing this.
kdf
Old Apr 12, 2007 | 09:43 PM
HO-alts-Rick
kdf
Here it just has to have a CAT if it came with one. Do you know where I can buy one?
Old Apr 12, 2007 | 09:44 PM
Big2Bird's Avatar
Big2Bird
Then you are stuck with the cat, and stock emissions equipment. The cat needs the AIR system to work.
To 81 headers
