Ive got a ZZ383 im dropping in a 79, and Im having a clearance problem with the balancer touching the center crossmember, and the idler pulley is hitting the crossbar mount for the upper control arm on the right side. It is a setup from GM performance parts. Anyone have any insight?
The ZZ383 should be no different in the mounting and positioning than a standard small block right?
The crank pulley may not be correct, like a BBC crank pulley that maybe has a larger diameter and a longer back spacing.
I put serp on my small block, and I have a full finger between the pulley and the front cross member.
I do not have a cross bar, but I think you may have to go at it with a grinder to give you a little room. Can it be pulled apart and re-welded for more room?
Well I dropped the motor in for a test fit, and luckilly I did because thats when I noticed these issues. I have A/C so Im thinking that might be why the balancer pulley is larger. Id take some pics, but I took the motor back out to address the issues. Some pictures I am seeing shows the idler pulley mounted further to the inside. It seems as though I might be seeing setups used from 4.3L motors.
All the small blocks have similar setups. The driver bracket is the same all across the board. Same goes for the water pump pulley. The power steering pulley has two sizes, and the crank pulleys are all the same for the small block with the exception of the ones that are integrated into the balancer itself.
The passenger bracket has two variations. One, the 4.3 and truck bracket, does place the tensioner a little closer to the center of the setup. The F-body passenger bracket leaves more space between the two. The height is almost the same for both of them.
Some had an idler pulley mounted down where the smog pump would go, but the casting is the same so it can be removed, and a smog pump or delete pulley can be mounted.
I suspect that you may have a BBC serpentine pulley on the crank. I have not been able to find two to compare, but I think they are different diameters and this may be causing your cross member clearance problem.
Can you measure the crank pulley's overall diameter for me?
Hmm...that is correct. Have you test fit the belt with all the accessories bolted on? It could be that the balancer is not seated on the crank shoulder.
Yeah I have it all together on the motor. I see that some people leave the idler pulley off the motor, but Im not sure if that will be ok or not since the run from the compressor to the crank is pretty long.
That actually is not a problem. Here is a pic of mine, which is the F-body setup, modified to house a second alt and no lower pulley at all.
Lets go over the common things. Your 383 is a small block casting so it should be the same. The motor mounts are probably good and the same as mine. With the motor and mounts in the same place you should have at least a full finger between the pulley and the cross member.
The truck setup actually puts the belt about .20 inch farther aft. I also had clearance issues with the F-body drive in my 75, but with the truck stuff it all fits great.
I would not delet the idler pulley if your are running A/C. You will not have enough belt surface area to drive the compressor under a load.
The Camaro guys at the Thirdgen.org place have been deleting that lower pulley for years now and no one has complained of a slapping belt or insufficient contact with the A/C pulley.
DB
Not saying You can't delete the idler. I said I wouldn't. It was put there for a reason. The General could have saved a boat load of money if it wasn't needed.
DB
You are very right, they did actually they had a good reason and it was a place to mount the smog pump on a lot of cars. For the cars that did not receive the smog pump, they filled the space with an idler.
How is the transmission mounted? If you could drop the tail a bit the balancer will come off the front crossmember.
if you drop it and the drivetrain is not @ 4 degrees down (the diff should be 4 degrees up) the driveshaft will be out of phase and will lead to vibration
