Help with 74 tach
Old Apr 12, 2007 | 11:57 PM
ArcherVet's Avatar
ArcherVet
4th Gear
Default Help with 74 tach
Hello all, I recently purchased a 74 coupe. The tach will work without any problems for the first 10 minutes the engine is running. Then the needle drops to zero. If the car sits for a while (not running) the tach will start working again. Has anyone had this problem? Can the drive assy. be removed from the distributor housing without removing the whole assy. from the block?
