Points and Plugs
The distributor and triggering method has nothing to do with the heat range of the plugs with the possible exception that with a "hot" electronic system you may be able to stand a little colder plug without fouling them out at idle or in traffic.
Your heat range depends on how radical your engine is built. In AC ranges most small blocks use "44" heat range with some mild engines using "45". When you start into 350-350s or 350-370s (CID-HP) you ususally need "43" plugs, possibly "42s".
Too cold a plug can foul and too hot a plug can burn a piston or preignite your compressed charge killing high load high rpm power.
