Quickly fouled plug #4 (77 L48)
Old Apr 15, 2007 | 04:11 PM
C3nMe's Avatar
C3nMe
Default Quickly fouled plug #4 (77 L48)
I've been doing some research about a problem where my #4 cylinder is fouling very quickly with oil and I am on the path that a valve seal may be to blame (at least as far as I can tell, that is the kind of seal I think is there).
No other cylinders show any serious issues (plugs looked good, but there was a light amount of oil near the plug seat)
So the questions are:
Does a plug that fouls so quickly with oil seem like a valve seal? Or is there another possible cause to be considered?
I've read a Chilton book about the process of replacing these ...and it doesn't seem to scary -- is that something I can do myself and what special tools may be needed (aside from a valve spring compressor)?
I've got a autocross race coming up in two weeks, so I'd like to have this a little better before then, as I have to drive 5.5 hours just to get there.
Thanks so much.
Old Apr 15, 2007 | 04:35 PM
7T1vette's Avatar
7T1vette
Could be a bad plug or plug wire causing a miss and a collection of oil on the plug when it finally fires.
Old Apr 15, 2007 | 04:40 PM
C3nMe's Avatar
C3nMe
That was my thought originally as I found the plug boot was melted and I assumed it was shorting to the exhaust manifold. However, I replaced the wire and bought racing "heat boots" that look like asbestos, but I think it's Kevlar -- but the plug boot looks good this time.
I pulled the plug and found it fouled bad. I replaced it and checked it after driving it to work and back and it's already coated (although not so bad as before where the cylinder wasn't firing due to gunk-short). While the new plug was in there, the car ran good and smooth -- definitely firing on all 8.
For this reason, I don't believe it's electrical at this point.
I agree that it's a cheap and obvious place to start ...but I believe I have done reasonable things to eliminate that (or as far as I know)
Brian.
Old Apr 15, 2007 | 06:34 PM
7T1vette's Avatar
7T1vette
A leaky intake valve seal might cause it to foul; I don't think a leaky eshaust valve seal would foul the plug.
Old Apr 15, 2007 | 07:34 PM
C3nMe's Avatar
C3nMe
How ugly of a job is that to fix with the heads installed? If I did replace the seal on one, should I just change the pair at the same time just in case?
Brian.
Old Apr 15, 2007 | 08:19 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Have you had the intake manifold off recently ?
Old Apr 15, 2007 | 08:28 PM
w1ctc's Avatar
w1ctc
Follow this thread to the end. May be of help
http://forums.corvetteforum.com/show....php?t=1673435
Old Apr 15, 2007 | 10:43 PM
C3nMe's Avatar
C3nMe
Me? No. Bubba? Yes. The engine was rebuilt (allegedly) about a year before I got it and I've had i going on 3 years. I say allegedly because I have receipts from the previous owner showing the work and where it was done -- but based on what I've been finding, the guy was a complete moron (mis-matched plug, motor mounts that had bolts started but never tightened, some valve springs changed -- not all) and so on. I cannot vouch for the quality of that work.
The only thing I have to work with is that the rate of fouling has gone up recently and was not this bad since the day I bought it. That is why I suspect it's a recent change. However, that doesn't mean something Bubba did couldn't have just failed on me.
Are you thinking misaligned intake gasket?
Brian.
Old Apr 15, 2007 | 10:48 PM
C3nMe's Avatar
C3nMe
w1ctc ...oh, snap. This is a great post. I searched and didn't find anything, but it seems like it just got started. Lots of good information and it does seem to have many parallels to my situation, except the engine type and year -- which may change the detail parts but not the overall function.
I'm going to have to get a good compression tester, so I can verify the valves and stuff are in good shape. I'll pick up some rings and see about changing the two on that cylinder and see what happens. I'll just have to read up on how to set valve lash (I've replaced some upper parts but I don't recall doing that).
I don't think I can pull intake or heads off before the race in two weeks ...can you pull a head and reinstall it without having it milled? Or does pulling it often mean milling?
Thanks for all the help so far ...sometimes it's enough to have a sanity check.
Brian.
Old Apr 15, 2007 | 10:57 PM
w1ctc's Avatar
w1ctc
Brian.
If you go all the way to the end (page 5) he found a bad "o" ring.
Old Apr 15, 2007 | 11:06 PM
C3nMe's Avatar
C3nMe
Yeah, the pics were very telling in his case and I was suspecting that in mine, but was nothing more than a hunch. My plan is to get some new o-rings and install them on both valves in that cylinder. If nothing else, I can see what affect that has on the symptom -- but the money is on that is the likely cause. Sorry if my response suggested I hadn't read the full article and understood the o-ring (or valve seal -- it seems to have many affectionate names) was the likely source of his leak.
I'm sure I would have missed it if you hadn't pointed it out, so I'm quite grateful for your assistance (more so if it happens to be the problem)
Cheers!
Brian.
Old Apr 15, 2007 | 11:28 PM
MotorHead's Avatar
MotorHead
9 times outa 10 one fouled plug is a misaligned intake gasket
Old Apr 15, 2007 | 11:31 PM
C3nMe's Avatar
C3nMe
Oh, you are so evil!
This will be a good time to be in the 90th percentile
Brian.
Old Apr 19, 2007 | 12:09 AM
C3nMe's Avatar
C3nMe
Default Update
Thanks everyone for the great help with this ...I've made some progress and I figure I'd post the update and perhaps toss out one more question.
1. I replaced both of the valve stem seals on #4 intake and exhaust cylinders and re-lashed. The old seals were brittle/hard and broke and pushed out of the channel they should be in (not entirely ...but definitely crap). Of course, being this brittle makes me worry that the rest are just as bad (thanks bubba).
2. When I hooked up the air compressor, I noticed air coming out of the EGR port (I had it removed), and this didn't seem normal to me. I get the impression it should have held air without leaking it back through the egr side. So I opened the exhaust value while the cylinder was under pressure and I got a pop of air. Nothing like when I did it with the intake. Something to be concerned with? Valves all gunked up? Time for some Seafoam?
I guess I wish I had a way to find out what else was lurking. I fired it up and it ran after the work, so it couldn't be too bad (like when I code -- did it compile? Then it works. Was data returned? Then it was right)
Thanks,
Brian.
Old Apr 19, 2007 | 07:02 AM
bashcraft's Avatar
bashcraft
Did you do a compression test? Sounds like a burnt exhaust valve.
Old Apr 19, 2007 | 11:41 AM
C3nMe's Avatar
C3nMe
I didn't have time to do it last night, but I already bought a good tester with expectations of doing that soon. I guess that will be tonight
Burnt valve ...crap. That can only mean one thing: the heads are coming off which pretty much means a redo. Ugh.
Brian
Old Apr 19, 2007 | 11:54 AM
TimAT's Avatar
TimAT
Burnt valve is possible. More likely a chunk of carbon on the seat. Do the compression test- Disconnect the ignition, block the throttle wide open, pull ALL the spark plugs and start checking. Low to high should be within 10% give or take a bit. Look at the first stroke on the compression tester and then one a little later. I usually give them 5 or 6 and see where they are. Record the numbers and let's see what you've got..
To Quickly fouled plug #4 (77 L48)
Old Apr 19, 2007 | 11:56 AM
C3nMe's Avatar
C3nMe
Thanks. That seems like a reasonable approach. If the issue is that there is a carbon deposit ...is there an effective way to clear that out without pulling the heads? Some kind of "tune-up in a can" product perhaps?
Brian.
Old Apr 19, 2007 | 12:15 PM
BBNJKen's Avatar
BBNJKen
"Tune-up in a can" sounds like a beer to me!!
I've used the old time msited water into carb an elevated RPM to clear out suspected carbon deposits. The engines I did that to ran smoother afterward, and while I didin't tear the engines down to get pictures, I surmised the water did the trick. Perhaps Seafoam or other such products would accomplish the same effect, don't know.
BB NJ Ken
Old Apr 19, 2007 | 10:29 PM
C3nMe's Avatar
C3nMe
Well, crap. Sounded like a great plan until I tried to execute it -- and now I have a new symptom. No start.
I ran the car briefly last night after putting the valves back in, and it ran fine. Today, I have lights and power, but when I crank, the lights only dim slightly (so there is some current draw when key is moved to start, but the lights don't go out totally like the hi-current windings were being engaged). There is no click or any other noise. To rule out the battery being too low, i have it on a 6A charger to see if that makes any difference, but things seem too "bright" and don't dim enough for me to be convinced that is it.
So, since it's hard to test the system as I can't turn the key and be under it at the same time, anyone know what might be a good place to start? Otherwise, I would suspect a stuck bendix.
Where would you look?
Brian.
