Idler arm replacement or not??
Old Apr 16, 2007 | 10:17 AM
Sweet L82's Avatar
Sweet L82
Default Idler arm replacement or not??
I have the idler arm unbolted from the frame when I removed the oil pan. Not really sure if it is bad - looks to be the original. How do I determine wear? Would I notice any more precision in steering with a new one?
Old Apr 16, 2007 | 10:58 AM
jackson's Avatar
jackson
May be difficult to gage wear with it off car.
Suggest you get a new one ... it'll probably help.
Suggest you get one locally and in MOOG brand ... MOOG's the best & only few $ more than white box.
Old Apr 16, 2007 | 11:26 AM
merlin5353's Avatar
merlin5353
St. Jude Donor '07-'08-'09-'10
Do you have to replace the whole idler arm, or just the bushings?
Old Apr 16, 2007 | 11:27 AM
lars's Avatar
lars
Bolt it back up to the frame. Then, grab a tire/wheel and move the tire/wheel back and forth. If the idler arm allows vertical movement of the centerlink, it's bad and should be replaced. If there is no movement, you gain nothing by replacing it.
Old Apr 16, 2007 | 11:28 AM
lars's Avatar
lars
The idler arm is serviced & replaced as an assembly. The bushings are not servicable.
Old Apr 16, 2007 | 11:36 AM
merlin5353's Avatar
merlin5353
Thanx..
To Idler arm replacement or not??
