trailing arm removal
Old Apr 16, 2007 | 04:24 PM
Ken 6645's Avatar
Ken 6645
Navigator
Default trailing arm removal
I've got a 77 that needs to have both trailing arms removed. The bolt holding the arm in position is froze up and won't budge .Anyone got any suggestions or hints or want to come by the garage and help me remove this bolt ??? LOL-I've owned this car for 28 years but after this round of repairs I am about half tempted to sell this money pit.I'm getting to old to be fighting around with this old car
Anyway -Thanks in advance
Ken
Old Apr 16, 2007 | 04:27 PM
luerja's Avatar
luerja
your best option is to use a saws all and some good blades.
Old Apr 16, 2007 | 04:28 PM
Durango_Boy's Avatar
Durango_Boy
A reciprocating saw, and a few demolition blades from the hardware store. Demo blades are designed for all kinds of heavy duty ripping and they are long. Buy a few of them.
Old Apr 16, 2007 | 04:56 PM
toupstrio's Avatar
toupstrio
I used a sawsall on mine the first one took about 30 minutes to cut. The second one I gave up and used a torch. If you use a torch wet down the rubber bushings and keep water and a fire extinguisher ready.
Old Apr 16, 2007 | 05:49 PM
racecardrvr4's Avatar
racecardrvr4
i had the same problem with mine. luckily the body was off the frame. but i used a 4in grinder. even after i had chopped the nut off i still couldnt get the bolt out the shims were stuck and were holding the the bolt. best suggestion is the torch. forget about the bushing, order a new one their cheap enough. save the frustration and get it over with.
Old Apr 16, 2007 | 06:04 PM
Red 69's Avatar
Red 69
A slide hammer as used by the auto body industry can pull the T/A shims out and expose the bolts. Once this is done, the sawsall makes fast work of the bolts and the T/A's are out. A slide hammer can be had from Harbor Freight for $20.
http://www.harborfreight.com/cpi/cta...emnumber=92639
DETAIL SLIDE HAMMER
Lightweight hammer provides just enough force for small dents, trim and detail work
Comes with 1-1/2'' diameter cone, 2'' L wedge and 1'' round hammer for beating, hooks for pulling
Knurled hammer for nonslip grip
Vinyl coated hand grip
Old Apr 17, 2007 | 06:19 AM
7T3C3TTZ07's Avatar
7T3C3TTZ07
Sawsall with blades titled "the torch." I used about 2 blades per side on those Grade 8 bolts. Remember to keep track of the shim stack. It will make it easier to realign the rear end. Good luck.
Old Apr 17, 2007 | 06:53 AM
Gordonm's Avatar
Gordonm
I have been selling Lenox blades for years. You need to get some good Bimetal blades, preferably Lenox. If you can find the demolition blades or the Gold Demo blades they are definitly tougher. Use a little cutting oil and if you have a variable speed sawzall don't go all out on the speed. Run at about half speed and cut away. You will be able to do the job with one blade easy if you do it right. Heat is your worst enemy. Most people just go as fast as they can with no lube and just burn up the blades.
Old Apr 17, 2007 | 08:20 AM
Edzred72's Avatar
Edzred72
Works great! Also...Menards carries a 12" Sawzall blade called "fire & rescue". Tough bi-metal blade that will make short work of those grade 8 trail arm bolts
Eddie
Old Apr 17, 2007 | 08:27 AM
KJL's Avatar
KJL
Before you pull out the industrial equipment, try soaking it with PB Blaster, Liquid Wrench or my favorite, Kano. Hose it down for a week every day. Then using a drift punch, knock it out. Just another option.
Old Apr 17, 2007 | 12:26 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
12" blades are way too long. 8" blades are perfect - I picked up some 8" bi-metal blades at ACE Hardware - it only took three to get the bolts cut.
To trailing arm removal
