Sufffix letters or numbers
Old Apr 16, 2007 | 09:38 PM
MikeMc71's Avatar
MikeMc71
Default Sufffix letters or numbers
Hello there, I have two c3 corvettes, and I am having a terrible time trying to fine the prefix numbers on both of these engines. They are both SB engines, one has a casting # of 3970010 (71) and the other just says 970010 (75) no three, which is kinda strange. The 75 has a J238 date, so I do believe it is a 78 engine, but not sure (68 woud be 327, I believe). Any help would be GREATLY appreciated!
Old Apr 16, 2007 | 09:40 PM
dgruenke's Avatar
dgruenke
There is a stamp pad on the block right in front of the passenger side head. It faces up. It should have the suffix numbers and a portion of your VIN on it.
Old Apr 16, 2007 | 09:53 PM
MikeMc71's Avatar
MikeMc71
Hmmm.....both of them appear to be blank.....paint buildup, perhaps? Let me check again.
Old Apr 16, 2007 | 09:55 PM
dgruenke's Avatar
dgruenke
You may have some dirt and grime build up. Clean it off real good and shine a flashlight directly on it. You should be able to make out some indentations.
Old Apr 16, 2007 | 10:04 PM
MikeMc71's Avatar
MikeMc71
No, both are blank. The 71 I know has been stroked to 383, the other I just got, and am not at all sure, but it runs very strong.
Old Apr 16, 2007 | 10:45 PM
dgruenke's Avatar
dgruenke
It could be that the blocks were decked during a rebuild. Most machine shops will take off the numbers when they cut down the deck.
To Sufffix letters or numbers
