Engine lift bracket --> homemade [pics]
Old Apr 19, 2007 | 09:12 AM
73bbc's Avatar
73bbc
MYBAD... For what it is worth at this point, I had the same concern about those manifold lifting plates when I was pulling the 454 out of my '73, so I did some calculations of thread strength in aluminum. It turns out that, even in the worst grade of cast aluminum, if you can get the 5/16 bolts to screw in at least 1/2 inch into the manifold, each bolt will support a minimum of 500 lbs.
This is true ONLY IF the plate you use is stiff enough to prevent it from bending when you lift the engine, and the bolts are torque to 15 ft. lbs. If you can get 3/4" of thread engagement into the manifold, the load handling goes up to 750 lbs. That's enough that one bolt would support a typical small block + transmission.
After I saw the numbers, I used a lifting plate like everyone else, but I made my own out of 1" thick aluminum.
Good luck with your lift
Old Apr 19, 2007 | 01:31 PM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
Originally Posted by norvalwilhelm
that doesn't make sense?? A load lever allows the hook from the engine hoist to be move back or forth to balance the engine or tilt as the case might require.
Having a load lever crosswise on the motor does nothing for tilting the tranny up or down???
I run my chain from front to back...
Keith
Old Apr 19, 2007 | 02:33 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Some of you people need to unclinch your sphincter
I used the lift plates dozens of times and witnessed them being used many more, a lot of those users were pros by the way.
Anyone ever see one fail that was used properly?
Old Apr 19, 2007 | 10:46 PM
Artsvette73's Avatar
Artsvette73
I am just guessing but the bracket may interfear with the master cylinder. Nice Job though
Old Apr 19, 2007 | 11:30 PM
TimAT's Avatar
TimAT
Default Why is everything so DIFFICULT??
I've used a 5/16 chain and 3/8 bolts from the left front to right rear (or the other way around) for like 35 years. Never had one of those fancy "load leveler" things, just dropped a bolt thru the chain on either side of the cherry picker hook, if I needed a different angle I take one bolt out and move it with a screwdriver. And I've done this on everything from Vettes to dump trucks back when Chevy made them.
Old Apr 20, 2007 | 04:23 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
no need to reinvent the wheel.
Old Apr 20, 2007 | 09:11 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
there's lots of room:
Old Apr 20, 2007 | 09:16 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Now that the engine is installed I might sell it on Fleebay.....
