A Few Questions
Old Apr 17, 2007 | 11:18 AM
GEORGE TAYLOR's Avatar
GEORGE TAYLOR
Default A Few Questions
1. Where can I buy a radio delete panel that blocks off the opening where the radio goes?
2. What is the pig tail spedo like looking cable that is protruding from the back of my spedo. dash? It is just under where the spedo cable goes in.
3. On a 69 rag top; the tops of both my door lock pillars are broken/damaged. I bought new panels from Ecklers.
My question is; how do i go about putting these in? Should I cut and put in the whole panel? or should i cut and only use the top portion ?
Any advice on this whould help.....If it were steel I would now the answer.
Thanks.
Geo.
Old Apr 17, 2007 | 12:15 PM
DZRick's Avatar
DZRick
1.-------- E-bay or check the catalogs
2.-------- speed warning, you have 2 needles in your speedo right?
3.-------- no idea
Old Apr 18, 2007 | 12:51 PM
GEORGE TAYLOR
Default Door Post Pillar Panel Replacement
Is there not anyone out there that knows how to repair this area and or replace this panel?
Old Apr 18, 2007 | 01:01 PM
S489's Avatar
S489
sometimes it takes a little while for the right person on read and reply, patience . . . i have absolutely no experience with that repair, but can't help saying that i'd default to replacing whole panel . . . but someone with experience will chime in anyways . . .
Old Apr 18, 2007 | 04:57 PM
DZRick's Avatar
DZRick
Pictures would help too and did you see my question .
Old Apr 18, 2007 | 06:58 PM
SIXFOOTER's Avatar
SIXFOOTER
Pics would help some. Generally I am in the swap out the panel camp, but it depends
Old Apr 18, 2007 | 10:46 PM
desi's Avatar
desi
1. Are you looking to just block off the radio area? If so, you could probably make something up yourself.
If you are looking for the "original" off a corvette, PM me
To A Few Questions
