side pipes
Old Apr 17, 2007 | 04:26 PM
bobbywyant's Avatar
bobbywyant
Default side pipes
I just got my side pipes from patriot with the four tubes , has anybody mounted these and how do the tubes mount to the pipes . Instructions were,nt that great.If somebody could give some advice, I have a 76. Thanks Bob
Old Apr 17, 2007 | 05:20 PM
stingraymaniac's Avatar
stingraymaniac
i have those on mine,the tubes are just a press fit,but i put some mounting paste around the collector before i pushed them togheter..
I mounted the brackets for the pipes on the side of the frame behind the Rocker panel that got them as high and close to the car as possible..
here is a pic of how close they are:
Old Apr 17, 2007 | 05:25 PM
bobbywyant's Avatar
bobbywyant
Did you take the rocker panel off? They look great! How do they sound?
Old Apr 17, 2007 | 05:50 PM
stingraymaniac
yeah you must take the panel of to get the brackets in place..
here is a soundfile of them and yes they sound great!
http://www.geocities.com/trrayzer/fett.mp3
Old Apr 17, 2007 | 06:04 PM
bobbywyant's Avatar
bobbywyant
Thank You sound great too!
Old Apr 17, 2007 | 06:20 PM
jetdoc's Avatar
jetdoc
I know there is a guy here who sells heatshields, but I was trying to do shopping at other places...anyone know of a place that sells them?
Old Apr 17, 2007 | 06:49 PM
EyeLuvCorvettes's Avatar
EyeLuvCorvettes
Not to thread jack or anything, but can you have the side pipes mounted and have the rockers still on?
Old Apr 17, 2007 | 08:20 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
I weld a boss on each piece to pull them together. I also make custom brackets to mount them to the frame and move them out a little more than the set above. The extra room allows for some cooling and keep the rocker panels from cooking. Also you do not have to trim the rockers with my brackets.
Old Apr 17, 2007 | 08:41 PM
ddale1977's Avatar
ddale1977
Here's a web site. BTW, I am putting sidepipes on as well soon. I'm going to do pipes without the cover. My wife is the only person that typically rides with me. I'm hoping to teach her not to touch (without learning the hard way). She's used to riding on a harley with hot pipes...
I presonally like the look without the shields...but that's just my opinion.
Doug
http://www.steelshields.com/html/styles.html
Old Apr 17, 2007 | 08:45 PM
Edzred72's Avatar
Edzred72
Of coarse! How you mount the pipes, will determine if/where you must notch the rockers panels out.
Eddie
Old Apr 17, 2007 | 09:03 PM
jetdoc's Avatar
jetdoc
Doug
I agree, they do look better. Believe me, I have burned my legs more than once on my Bikes too...maybe on second thought I should get them for safety reasons, lol, .
Old Apr 18, 2007 | 01:49 AM
stingraymaniac
cooking? i have no problem with that they look exactly the same as they did before the pipes,they get hot but never that hot.
Old Apr 18, 2007 | 03:48 AM
Bangkok Dean's Avatar
Bangkok Dean
When I first put side pipes on my Corvette I had two friends burn there legs really bad when getting out of the car. So I looked on the WWW and the only heat shields available were the Cobra Cheese graders. I bought a set but they looked so flimsy and cheep I decided to make my own. Well when I laser cut 1 mm highly polished stainless steel shields I posted pictures on this forum. The many remarks on how everyone liked them and would I make a set for them also, I decided to go ahead and make other designs. Then I went and applied for a license from GM to use there copyrighted names. Well to get a license is not easy or cheap plus they needed to see the quality first. The samples I sent to them must have been good as someone in the licensing company wanted them for his Vette.
BTW,I am now in the process of adding more designs like Firebird, Camaro and Chevy bow tie shields.
The many folks that have my Steelshields installed have been pleased with the looks and safety they provide.
Now the cheese grader shields do work to keep you, your friends and family from getting a serious leg burn but many owners really do like there Corvette to look as good as possible.
Old Apr 18, 2007 | 04:36 AM
supercalvin's Avatar
supercalvin
Sweet job Dean! That is one way of expediting the paperwork!
His sidepipe covers rock
When I go the sidepipe route his covers are a must.
Old Apr 18, 2007 | 11:26 AM
c69vete's Avatar
c69vete
St. Jude Donor '07
But a 69 has fiberglass rockers. 70 and up used aluminum.
Old Apr 18, 2007 | 12:04 PM
stingraymaniac
But a 69 has fiberglass rockers. 70 and up used aluninum.
aah ok! thought they where made of alu painted black
Old Apr 19, 2007 | 10:19 AM
LannyL81's Avatar
LannyL81
Soooo....if by chance I do get to put sidepipes onto my '81...how would I find out what you have and order a set? Web page?
To side pipes
Old Apr 19, 2007 | 11:22 AM
Bangkok Dean
Here you go
Old Apr 19, 2007 | 02:27 PM
ram100987's Avatar
ram100987
I'm not worried about shields one or two burns and they learn to step OUT (either that or wear pants) I love them though, they look great and I want the BTS baffles but dont have the money for them right now so I just have the hooker reverse flow muffler with several large holes drill as deep as I could get. Dunno if it helped the flow any but its definitely louder.. the only issue I have with them as that I just can get them to stop leaking where the pipes slides over the collector. mainly near the bracket to tighten it. Anyone know of a way to keep it from leaking ( maybe something to put inbetween to seal it)
Old Apr 19, 2007 | 09:31 PM
TheMongoose's Avatar
TheMongoose
I have a 76 also. Here are some pics of the install. I bought the cobra covers for mine. If you get them you need 4" clamps for the front of the pipes. The 3-1/2" ones they sell don't fit the Patriot pipes which is what I have, same as oyu.
