My 76 has a '92 L48 copy crate engine in it, has done only about 20K miles, I have been considering power adding options, and I have access to turbochargers for next to nothing. Has anyone else done a twin turbo deal under the rams horns, the intake can be fed to a pressurised carb box via an intercooler. Sound feasible?
I don't believe the engine could stand up to a twin turbocharger system. Now a single turbo limited to something like 4 1/2 to 5 pounds of boost could possibly work.
you can get turbochargers that cheap???? you'd probably have better luck with a supercharger or nitrous. But still if u can get turbo cheap, might as well try..
I would be afraid to run nitrous through a stock L48 with the cast pistons. I know that there are some forum members that have installed turbos. Oddly enough, forum member Twin Turbo has installed twin turbos on his car.
Its not exactly the same as a L48, whilst these Goodwrench crate engines were not world beaters, they do have some redeeming features such as 4 bolt mains and flat top pistons, I admit they are cast but should stand about 8lbs of boost, fine.
Heres a link for this type of crate engine dyno testing, it's an interesting series of 8 articles where they eventially got over 400hp out of it without changing the shortblock except cam. http://www.chevyhiperformance.com/techarticles/46320_gm_350_crate_engine_build/
It is a 4 block main, but those should be dished, cast pistons. I think the CR on that engine is advertised at 8.5:1.
I am not sure what dollar amount is "next to nothing", but if it costs anywhere near a typical turbo, you could probably do a fairly good head and cam upgrade for less money.
I've wondered the same thing... With the L-48 having an 8.5:1 CR, it would seem to be already set up for a low pressure turbo or supercharger. With a 2-bolt main and cast components, you wouldn't want to put too much stress on the system. But I would think you could get an extra 60-80 HP out of it pretty easily...and that would get the engine up to about 300 HP at the wheels. If the turbo (and related hardware) can be had readily and you can do the pipe welding...why not?
Speaking of that, could you scavenge a turbo off some other wrecked production vehicle to do that job? What unit will be a good match with the L-48 engine?
i dont know what l-48 you're talking about, but mine is rated at 165hp...an additional sixty or eighty places it around 200hp at the wheels ....pretty dismal for so much work
You can run 7 to 9 psi without major mods, I put a turbo on a 1974 Ford with factory cast pistons (pre-hypereutectic) running 9 psi with no trouble. Now days factory pistons are cast using the hypereutectic process. I think the Corvairs ran around 7 psi, cast pistons from the factory.
