Mandrel bent exhaust kits??
Old Apr 17, 2007 | 10:45 PM
supervette2's Avatar
supervette2
Default Mandrel bent exhaust kits??
I highly doubt its this simply, but does anyone know of a kit that would exist in 3inch size. Anyways just a little update, I know its been a while over that long winter up here in MN. Im back on the project car. The procharged C3 lives and runs awesome All I need is the exhaust to be put on and pictures and videos will be updated to the forum. Im sure my neighbors are real happy with my car driving around the neighborhood all weekend loud as @#$%!!!
Any muffler suggestions would be appreciated. Ive been kinda looking at dna mufflers but still am not sure. Bassani seems like the best idea.
Old Apr 17, 2007 | 10:47 PM
supervette2
oh yeah if you can please post links to sound byte.
Old Apr 17, 2007 | 11:43 PM
big_G's Avatar
big_G
I probably will also do a 3 inch on my ProCharged '68, but I wonder how I could possibly use it...absolutely no traction on the 295's once the revs kick in.....How much boost do you get at 3,000 and 5,000rpms? I have 5lbs. and 10lbs. respectively.
Old Apr 18, 2007 | 06:09 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I don't believe there are any pre-made 3" kits for C3's. It's probably because the clearances are so tight by the time you get that size. Several on here have 3" pipes, but all of us had them either custom bent or went with the pre-bent pieces and welded them together ourselves. I only have ~1/8" clearance as the pipes go thru the crossmember .
Old Apr 18, 2007 | 08:51 AM
Xakk's Avatar
Xakk
Once I get a new welder, I'm going to give this a go, only in 2 1/2. It's far from plug and play, but with a little time, patiences and a BFH, everything should be there to get it done.
http://store.summitracing.com/partde...5&autoview=sku
Old Apr 18, 2007 | 12:30 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Jason,
I normally jack the rear of the car up underneath the rear-end. But your x-pipe is right under there. How do you jack up the rear-end now? I'll also be doing a 3" system in a few weeks with an x-pipe and am trying to decide where to put the x.
Old Apr 18, 2007 | 10:28 PM
Jason Staley
Originally Posted by tshort
Jason,
I typically jack it up one side at a time, with the jack just behind the tranny x-member. I then place jack stands along the sides as close to the wheels that I can get them.
Old Apr 19, 2007 | 05:37 AM
dk-corvette's Avatar
dk-corvette
Wow Jason,
That is really a tight fit you have between the crossmember and your exhaust pipes. It's looking real nice and I guess the rubber-hangers you have there helps you avoiding problems with the pipes knocking on the member, or what? Also the flanges in front of the crossmember making it possible to remove the complete exhaust in one piece is a real nice feature.
I also noticed the nice red yoke cap you are using on the transmission yoke. Do you know what make that is? I have been looking for such ones for a while now without success so I would love to hear what you are using. I don't feel safe with the tiny straps I have down there at the moment.
Best regards, DK.
Old Apr 20, 2007 | 08:59 PM
Jason Staley
Yeah, I use 3 Ford late model rubber hangers at the x-member to keep the system from rattling. The system comes out not too bad, but it can be a little bit of a hand full.
The red tranny yoke caps are Moroso caps. I can't remember what part number they are, but they fit the TH400 yoke in the Richmond great. Moroso has several sizes to fit almost any universal joint size commonly ran in rear-wheel drive cars. They color code them for easy identification. The caps are manufactured from 7075 aluminum and fully incase the bearing cap, spreading the load out over the complete cap. I run similar ones on my drag racing car for years now with no failures. Plus they're just pretty .
Old Apr 21, 2007 | 06:22 PM
dk-corvette
Hi Jason,
That was strange. A few weeks ago I mailed Moroso and asked if I could use one of there caps for my car. They told me that they didn’t have any for a 69 Vette!!!
So, what type of u-joint do you have on your yoke? Is it a 1330?
On my new driveline I’m having a solid yoke like this at the trans: http://store.summitracing.com/partde...5&autoview=sku
But I would really like to have a set of the red caps at the diff if they fits there? I’m running a 1330 joint at the diff. Do you think a set of the red ones will work here?
Best regards, DK.
To Mandrel bent exhaust kits??
