matching numbers on 1982 ce
Old Apr 19, 2007 | 10:43 AM
dapieper62's Avatar
dapieper62
2nd Gear
Default matching numbers on 1982 ce
im trying to buy an 82 ce. am new at this. isnt the serial number on the engine supposed to match the last digits on the vin? and where exactly is that number? and what does the ck digit in the vin actually do/tell?
Old Apr 19, 2007 | 02:02 PM
bluesilver82's Avatar
bluesilver82
http://www.corvetteactioncenter.com/...1982/82id.html
http://vetteworks.tripod.com/1982SPECS.html
see if this helps
Old Apr 19, 2007 | 09:12 PM
Toms82's Avatar
Toms82
Hi,
The number you are looking for (the VIN derivative number,) is found on a machined pad on the passenger side of the engine between the cylinder head and the water pump. The sixth digit of the VIN will be a "0" on the CE only , the other 82 Vettes had an "8" in that position. The ninth position is the "check" digit, but I don't know what it means.
Good luck with your search.
Tom
To matching numbers on 1982 ce
