Best ATF?
Old Apr 20, 2007 | 12:44 PM
Ken73's Avatar
Ken73
Cruise-In III Veteran
Default Best ATF?
I've completely rebuilt my 700R4 in the '82, going so far as to not only replace any part that could possibly break, but also mic out each and every steel and clutch to make sure I have my tolerances within spec. I installed the Transgo shift kit as well as a special cooler setup I have that's right up front, underneath my new (universal) AC condensor. I have a brand new converter with a higher stall than stock, and I'd like to know what the best ATF to put in it is for longevity.
The motor I've built will have about 300hp peaking around 5000RPM. It's still a CrossFire so it'll be quite torquey. After that it's into 3.23 gears I'm putting in the back and 275/50R15 tires.
I'm thinking synthetic?
Old Apr 20, 2007 | 01:02 PM
JimmyS5600's Avatar
JimmyS5600
Active Streak: 90 Days
Ken if it where me I would go with either Amzoil or Mobil 1 syn.
Iam sure others will chime in but Iam a big beleiver in either of those.
Jimmy
Old Apr 20, 2007 | 05:00 PM
Ironcross's Avatar
Ironcross
B&M has a fluid called "Trick Shift" used in all there performance transmissions. [GM Ford Chrysler] I was on contract with them several years ago, and it`s in reality "Ford type 'A' ATF" that I used in a B&M Torqueflite 727. Shifts hard and solid .
Old Apr 20, 2007 | 06:53 PM
marshrat99's Avatar
marshrat99
The BTO guys suggest using any reasonably priced ATF but change it and the filter annually.
Old Apr 20, 2007 | 07:00 PM
strokervette's Avatar
strokervette
I use the cheapest stuff I can find but I change it more often than others. As long as its clean its good.
Old Apr 20, 2007 | 07:10 PM
machineman's Avatar
machineman
Use the best synthetic that your wallet can handle.
Old Apr 21, 2007 | 10:06 AM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
I use Amzoil in my Dodge grand Caravan. these things are known to eat transmissions. I have 170,000 miles on the origional tranny. I change the fluid / filter every 60k.
Old Apr 21, 2007 | 10:19 AM
7T1vette's Avatar
7T1vette
The heavy duty truck automatic manufacturers (Allison, ZF) all know that synthetic fluid is lightyears ahead of organic oil when it comes to reliability. My 36 year-old THM-400 has never been out of the car and has always had Dexron in it (and I'm not about to change that now). That being said, if I ever have to pull it and rebuild it, it'll have synthetic fluid but into it.
Old Apr 21, 2007 | 10:37 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I would recommend synthetics, and use Mobil 1. They handle heat better which is the enemy of automatics.
Old Apr 21, 2007 | 11:08 AM
Ken73's Avatar
Ken73
OK So I was pretty well sold on synthetic in the first place - so I guess the next question is, which brand, and which TYPE? I've seen Mobil 1 at Wal-Mart and Autozone so far, but only seen the MERCON (which I thought was for Fords) carried. However I read the label and it said for 2005 and earlier GM cars/trucks, it would work also. For 2006 and later, to use the Dexron version. Any thoughts?
Old Apr 21, 2007 | 11:57 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I have a slightly different view.
I'm a great believe in synthetic oils. They certainly last longer and some of them (Mobil 1 in particular) clean better, From seat of the pants testing in my own cars, I believe that the engines pull better on synthetics, I would assume by reducing friction. That's certainly what the sales research says. I like to use synthetic lubricants in everything EXCEPT
Automatic transmissions. I did try the trick, synthetic fluid in a TH350 and was never happy with the way it felt. Remember that ATs work by having clutches and steels rub together while the gears are switching to allow the gear to gradually engage. I found that with the synthetic fluid, the tranny slipped too much and then engaged a little too hard when the clutches finally locked. I would immagine that the parts, bushings in particular, will last longer but not sure if the higher temperature stabililty buys you anything. The internal seals will be damaged by the heat, regardless of the fluid type.
I'm with Marshrat. I like simple Dextron III from Castrol and change it rediculously often.
Old Apr 21, 2007 | 04:08 PM
V-Twin's Avatar
V-Twin
your behind must be awesome, noticing the difference in lubricant..simply AMAZING
Old Apr 21, 2007 | 06:58 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
I've got Amsoil in my Silverado & when I rebuild the TH400 this year I will fill it with Amsoil also.
Old Apr 21, 2007 | 07:41 PM
7T1vette's Avatar
7T1vette
Allison has a product they call "TranSynd" which is the synthetic they recommend. I don't know what company makes it, but if you call up a Detroit Diesel service outfit, I bet they can steer you to the source. I have no knowledge of whether it "acts" differently than other synthetic ATF's, but I know Allison was very concerned about clutch frictional behavior differences and settled in on TranSynd.
To Best ATF?
