Backfire Nightmare
Old Apr 23, 2007 | 07:09 AM
bradzap's Avatar
bradzap
Default Backfire Nightmare
I have a backfire through the exhaust problem.
It is present under load only. I can’t get it to backfire in the garage.
I put a mild cam in over the winter along with an intake. I have my timing set correctly 12 initial 32 total, and I’m currently testing with the vacuum advanced plugged. I richened the Quadrajet 2 jet sizes per Lars paper. I noticed it was running rich and the idle mixture screws had no effect on the idle quality. I looked into the carb with the timing light and fuel was dripping from the primary fuel ports. I would expect to see a mist. I then put the original jets back in the carb and check the float level again. I had the same backfire problem along with the fuel dripping. It seems to be running very rich. Is this common to the exhaust backfire? Also, I am considering changing to a lighter power piston spring. I tried testing the power piston, by pressing it down thru the fuel bowl vent, but I had no change in performance.
Any tips would be greatly appreciated.
Old Apr 23, 2007 | 09:04 AM
69vettester's Avatar
69vettester
Old Apr 23, 2007 | 09:06 AM
Jims79's Avatar
Jims79
I would check your timing then adjust the carb.
Old Apr 23, 2007 | 10:55 AM
bradzap's Avatar
bradzap
I'm confident timing is set correctly, and adjusting the carb doesn't have an effect. Anyone know if a mild cam would require a power piston spring change, or what else would cause the Quadrajet to run rich and backfire through the exhaust?
Old Apr 23, 2007 | 11:27 AM
sly vette's Avatar
sly vette
The unregulated fuel you see dripping in your carb is the problem in my opinion. Check the needle and seat that the float controls and make sure the small spring did not come off the float or the needle.
Good Luck and let us know what you find.
Old Apr 23, 2007 | 11:39 AM
noonie's Avatar
noonie
You may have sagging float too. Symptoms are of too high a level.
Replace both valve and float??
Old Apr 23, 2007 | 11:55 AM
bradzap's Avatar
bradzap
Thanks, I'll pull it back apart and check the float when I get home.
Also, has anyone has a problem with the power piston sticking in its corresponding bore. Mine seems to function properly, but it is difficult to install/remove. Also, that plastic seal on top of the power piston is shot, but I don't think that in critical the it's function,
Sly, I've enjoyed you write-up on the T5 installation, how's the progress?
Old Apr 23, 2007 | 12:07 PM
sly vette's Avatar
sly vette
Trans is in and working with a few small problems.
http://forums.corvetteforum.com/show....php?t=1685375
Old Apr 23, 2007 | 12:10 PM
noonie's Avatar
noonie
You can polish the piston and bore with very fine sandpaper and test for smoothness.
You can stake the phenolic washer very lightly.
Old Apr 23, 2007 | 12:34 PM
mxscooter's Avatar
mxscooter
I concur with the needle/seat theory -
me = same thing
some bozo put teflon tape on the line threads, and a booger tore off and clogged the seat..
To Backfire Nightmare
