I am still fighing an over heating problem although I am running a Victor Jr aluminum WP, Dewitt rad, dual spals and Indy front spoiler.
I have the following parameters set. 454 +.030\Aluminum heads intake\Demon carb\solid cam\10:1 comp.
180* stat
70/30 water vs anti freeze mix with water wetter.
low fan setting on spals kicks on at 160f. High kicks in at 200f
advance @ idle is 15*
36* advance all in @ 3000
The car is raising to 230* not in traffic! Also getting a lot of run-on after I shut the car off and smoke comes back up through the carb.
I am figuring the problem lies either in the timing or the carb setting. Ideas???
I assume you have all the foam atound the rad etc.
Try shooting the water outlet etc with a temp gunto establish the gauge accuracy.
Also the in rad temp vs the out rad temp to find the temp difference.
Try one of these tstats with much greater flow.
You may also try to block off the pump bypass. See Stewarts Pump Tech articles.
Lastly make sure your carb jetting isn't too lean.
Run your vacuum advance from a manifold vacuum source so you get an additional 16 degrees of timing on top of your 15 initial. This will give you 31 degrees of timing at idle, and this will run your engine significantly cooler.
Thanks lars I will try that tonight. One other question for you. When I installed my distributor the first time I did it 8 * advanced so I need to add that 8* to whatever the timing light is set at correct? Examble if I dial into the gun 15* and move the distributor to whiere the light pulses on the o* mark on the balancer I would essentially have 15* + 8* = 23* correct?
BlackRat; you can test that yourself before starting any changes: you say it is set at 8 deg at idle now, so with your timing light, dial it to 8 deg, and the 0 deg line on the balancer should line up with the 0 degree mark on the timing tab.
thanks
wade
No that is incorrect. If you set the timing light at 15 degrees and it shows up 0 you are at 15 degrees. If you set it at 23 and it shows up at 0 you are at 23. It does not remember where you are set at.
Ok so if I inserted the distributor with the balancer 8* adv mark lined up with the 0* on the timing tab I do not need to compensate for that when setting the timing?
I have my vacuum advance conected to a manifold port as Lars is suggesting, this works great.
My next move is to install a Stewart stage 2 pump for the extra flow at idle.
Do as noonie has said, the Robert-Shaw is the best T-stat design I have ran across.
Neal
Thanks guys I will try some of these suggestions. lars\Neal are ya'll saing to actually put a vaccum fitting into one of the intake ports and run the advance from there and not to the manifold vac port on the base plate of my Demon?
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Just for the heck of it, I switched my 383 from manifold to ported. It seemed to run a little better, but when I spent some time at stop signs the usual 180 went to 220. I was surprised that it could make this much of a difference.
Timing makes a huge difference. When mine was messed up the plug wires would get so hot you couldnt touch them!!!! now that my timing is all resolved my car runs much cooler at idle.
The water pump is the problem. Just like my Weiand Team "G" aluminum pump. They are made for high rpm race cars. I came across a rpm VS gallon per minute chart on my Team G at sub 4000 rpm it did not even put out 5 GPM and then it kicks in and increased to 38 GPM clear out to 9000 rpm.
I always had heating problems with twin spals and everything. The cure is to overdrive the pump. I also went to circle track washers instead of a thermostat. It is still pretty cool here and I'm now running the 1/2 inch hole. My motor would not ever heat up when i had the 7/8 inch hole. the washer set came in 6 sizes
Hmmm never thought of that. How do you go about overdriving the pump?
Wade
Custom machined pulley and pump face. I don't have milling machines and lathes so I had friends make the pulley out of chunk of aluminum. The aluminum pully is 2/3rds of the stock diameter so it is over driven 33% compared to stock pulley sizes.
The cost of these mods is high. It is probably cheaper to just get an aluminum higher volume pump. Or you might try the restrictor washers like I have instead of a thermostat. I don't even have to turn on my fans now where before I usually had them both running.
The width of the aluminum pulley did not clear the pump housing - So more milling time
Thanks. I noticed that you have all of your ports plugged on the water pump. I am not running heater hoses but I do have the bypass line hooked up from the op of the pump to the base of the manifold. Would I gain anything by eliminating that and plugging the hole?
I will try the washer method as well. did you buy those as a kit Where?
Wade
I got a six washer size kit from a local circle track race place and a reusable thermistat housing gasket. Jegs has a three set for $8.00.
The bypass does just what it says. It bypasses the block. that just does not help cool anything. I just don't think that even my high flow thermistats could flow enough. Like I said right now I'm using a 1/2 inch hole. when it gets up hotter I'm going to monitor it and probably end up using a 5/8th or 3/4 hole
Black Rat try the Stewartcomponents web site and read through the Q&A forum, tech section, and the 10 most asked questions, also on the tech section at near the bottom of the page there are some links to other pages that give the flow charts for pumps. Water flow is critical but so is air flow.
