82 with a Thud
Old Apr 25, 2007 | 03:04 PM
bluesilver82's Avatar
bluesilver82
Default 82 with a Thud
When I am slowing down almost to a stop a get a thud noise in the rear of the car. It does not make the noise when accelerating or even accelerating hard from a stop. It only makes the noise when I slow down almost to a stop. What could it be?
Old Apr 25, 2007 | 03:13 PM
GD70's Avatar
GD70
Possibly the drive shaft rear universal shifting as the load changes. Does it sound metalic? Do you just hear it or can you feel it as well. I once had a similar experience on a 66 skylark and it ended up being the universal. Upon removal it was bone dry and rusty inside under the caps.
Old Apr 25, 2007 | 03:54 PM
bluesilver82
That could be it. I do feel it slightly. I also have a noise comming from the left rear whell which I think is a U joint. Might be time to replace all 6 U joints then.
Old Apr 25, 2007 | 06:31 PM
7T1vette's Avatar
7T1vette
It probably is a bad U-joint. Once the joint gets up to speed, it settles in to a "comfortable" position. As it slows down, there is a point where the half-shaft is turning slow enough that the slop in the U-joint causes it to "slip". That is what you are feeling. It is hard to tell which U-joint that might be, but that is really not a problem. If all the joints are fairly old, it is probably best to replace them all (for safety of the car and for your peace of mind). Once you remove the half-shafts, the driveshaft removal is a "piece-of-cake" anyway. If you are doing them yourself (and haven't done them before), search for threads on this topic...there's lots already written up. You only need a big vise, the right sized ratchet socket(s), and the correct methods to do the job right and NOT distort the end yokes. Good luck.
P.S. If you have a "strong" engine and use it a lot, you should replace the joints with solid body Spicer joints (without a Zerk grease fitting). They are much stronger and just about as reliable.
Old Apr 25, 2007 | 07:27 PM
batsmith's Avatar
batsmith
I have a pair of half shaft joint about to blow any second, anything tricky to changing them out?
Old Apr 26, 2007 | 02:41 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
While doing all the pressed ends first, be careful to make absolutely certain the needles don't fall out of place in the process (this holds true for the u-bolt ends, too). If the locks won't fit without abnormal pressures, something's amiss. Try not to remove caps any more than necessary. Before applying torque to u-bolts, check that both caps are seating properly. Also, make sure zerks are installed in compression in the direction of forward drive. And, don't skimp on the parts.
Old Apr 26, 2007 | 02:32 PM
bluesilver82
Thanks guys. I may try this myself after reading up on it. If not, Ill send it off to a local shop.
Old Apr 26, 2007 | 04:24 PM
7T1vette's Avatar
7T1vette
As you are pressing the old joints out of the yokes, you need to do two things:
1. Soak them well with PB Blaster for a few hours prior to working on them;
2. Tap on sides of the yoke journals with a small hammer while you are pressing them out. (Don't pound them...tap them.)
Over the years, these bearing caps get locked into place and can be difficult to remove by pressing alone. Tapping on the journals while you are applying force to the joint causes them to "creep" out without binding. If you don't do this, you can bend the yokes and throw them out of proper alignment [which will cause the joints to wear quicker and tend to bind up].
To 82 with a Thud
