Rear End
Old Apr 25, 2007 | 04:30 PM
JustinD's Avatar
JustinD
Default Rear End
Is there a gasket between the cover and the main part on the diff housing?
Old Apr 25, 2007 | 04:39 PM
JustinD's Avatar
JustinD
Alos, what size snap rings go in the differential?
Old Apr 25, 2007 | 04:45 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
Yes and while putting mine back together we droped the whole thing it hit pretty hard put it on anyway and now guess what I got a leak but yes there is a gasket and it can look like its on correct but the holes miss lining up keep spinning it it will cover the holes perfect.Dont forget the additive and top off with GM lube add grease on a level ground. not when its up in the air.
Old Apr 25, 2007 | 06:03 PM
JustinD's Avatar
JustinD
Ok, thanks.
Old Apr 25, 2007 | 06:17 PM
GTR1999's Avatar
GTR1999
There is a gasket there. The ones you get at local stores,liek NAPA are not as thick as the GM gasket that I use. I use Ultra black on the gasket as well.
You'll find the snap rings are an odd size and I found 3 different thickness rings from various suppliers, as much as a .010 difference in them.
Check that housing that was dropped-cast iron is strong but it also breaks under impact.
Old Apr 25, 2007 | 07:03 PM
JustinD's Avatar
JustinD
It wasn't droped. But I am having trouble getting the joint on to the input shaft of the rear end. It seems to be too big but the half shaft ones fit fine.
Old Apr 25, 2007 | 07:58 PM
GTR1999's Avatar
GTR1999
There were 2 size pinion yokes used, you should have the larger one on yours if it's the original one. 3.625" If you have 3.250 you have an early pinion yoke on it.
If you're using Spicers then be sure they are compressed.
Old Apr 25, 2007 | 08:19 PM
JustinD's Avatar
JustinD
I'm using brute force ones. They have lifetime lube. I guess I'm not sure if this one is a different size than my old one.
Old Apr 25, 2007 | 08:33 PM
kayosnes's Avatar
kayosnes
Bought mine from ecklers.
And added some blue silicon youst to be sure.
no more leaking diff for me!!!
Old Apr 25, 2007 | 09:16 PM
JustinD's Avatar
JustinD
There is a problem getting gaskets around here. The chev dealer and all of the auto parts stores told me 5 days to get one. The mechanic at chev told me just to use grey rtv, he said that is what they have been doing. Hopefully it works out.
Old Apr 25, 2007 | 09:46 PM
76greg's Avatar
76greg
Autozone gasket stuck to the cover with a smear of RTV. No RTV on the case side.
Old Apr 25, 2007 | 11:29 PM
JustinD's Avatar
JustinD
I got everything back together. It turns out that one of the bearings in the u-joint cap was laying flat. After reading around, 80w-90 gl-5 gear oil and limited slip additive is the way to go. Is this right?
Old Apr 26, 2007 | 07:57 AM
GTR1999's Avatar
GTR1999
You use the 90 wt but I use Lucas 85-140 now, when using the posi springs I use 2 bottles of additive.
Old Apr 26, 2007 | 11:08 AM
JustinD's Avatar
JustinD
So I should take it back and get straight 90w
Old Apr 26, 2007 | 11:09 AM
JustinD's Avatar
JustinD
Also what is the capacity?
Old Apr 26, 2007 | 11:30 AM
Crash80's Avatar
Crash80
That is what we did with my 80 rear end redo. It doesn't leak. I think we used black RTV but you can use the color of your choice with the same results I am sure.
Old Apr 26, 2007 | 12:25 PM
GTR1999's Avatar
GTR1999
You can use what you have I just prefer the Lucas 85-140. 60 ounces total fluid is what I fill them to. 52 oil, 8 addiitve.
I use the gaskets, you can use RTV if you want. NAPA cover gasket #P-27938
To Rear End
Old Apr 26, 2007 | 02:08 PM
JustinD's Avatar
JustinD
It is bassically just filling it up to the fill hole. First asdding the limited slip stuff thn the rest gear lube. Right?
Old Apr 26, 2007 | 02:36 PM
GTR1999's Avatar
GTR1999
Yes, fill it when level until it starts to come out the fill hole.
Old Apr 26, 2007 | 04:18 PM
JustinD's Avatar
JustinD
Well, it moves under its own power. But when I get moving about 5 mph there is a clunk sound coming from the back. I figured it was a u=joint byt I can't seem to trace it back to anything. Do you guys have any sugjestions?
