Steering Valve Removal again
Old Apr 25, 2007 | 08:50 PM
79vetter's Avatar
79vetter
Default Steering Valve Removal again
In looking through the archives I have learned that it is a bad idea to use a pickle fork and that a puller is best to separate the valve from the pitman arm. I rented a puller from AZ but where does it fit? - lack of space..
Does someone have a pic that shows their puller on the pitman arm?
Old Apr 26, 2007 | 02:17 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Sorry, no. But, your info is correct. Stay tuned, someone will have the photo...
Old Apr 26, 2007 | 08:54 AM
79vetter's Avatar
79vetter
Ttt..
Old Apr 26, 2007 | 09:47 AM
Disco_Mike's Avatar
Disco_Mike
one of my projects soon.
Old Apr 26, 2007 | 06:15 PM
79vetter's Avatar
79vetter
Anyone else done this job?....
Ok, What do you think about removing the big nut on the other side of the pitman arm (at the steering box) and then just taking the whole unit out as one piece?
Old Apr 26, 2007 | 10:44 PM
kansas123's Avatar
kansas123
After I pour some fluid in my empty pump, bleed it per procedure, and fire up the car so that it can then spray fluid all over the place, I will be replacing my valve also, and hoses etc. LOL, I love taking stupid risks. I will be interested in reading more in this thread about the removal process. Thanks in advance.
Old Apr 27, 2007 | 10:19 AM
Tom454's Avatar
Tom454
It is a tight fit.... you have to locate a puller that fits.
The one I use is a heavy duty pitman arm puller sold by OTC.
#7311A.
http://www.otctools.com/products/detail.php?id=1824
As as side note, this one also just fits between the top & bottom ball joints to remove the ball joints.... with a little rigging.
Other people have located less expensive pullers that will fit.
I only have the OTC unit.
If you use a pickle fork, the side load imparted by the hammer & fork is transmitted to the gear box. This can damage the gearbox internals and the shaft lower bushing.
Edit...
AutoZone has two different "Great Neck" pitman arm pullers listed.... the 27016 which is 8.5 inches tall, and the 25262 which is 7 inches tall. Maybe you rented the tall one, or an entirely different one. I dunno.
Old Apr 27, 2007 | 10:31 AM
SIXFOOTER's Avatar
SIXFOOTER
I use 2 3lb short handles hammers. Hold one fast against one side of the joint and smak the hell out of the other side of the joint, the thing will fall out. Watch out for your thumb
Old Apr 27, 2007 | 09:03 PM
79vetter's Avatar
79vetter
Tom, I rented one that is exactly 3 inches long on the 2 arms of the puller...Heck- its still too big... I'm trying to put the middle bolt of the puller on top of the ball stud but the frame is in the way.
How big is yours?
Old Apr 28, 2007 | 03:06 PM
Tom454's Avatar
Tom454
Turn the steering wheel (left turn) and the joint will move away from the frame and toward the oil pan.... there is a spot where the tool will fit.
PS- My wife can't use a ruler... she still thinks 3" is 6.
Old Apr 28, 2007 | 04:59 PM
79vetter's Avatar
79vetter
Thanks Tom, you were right- there is now a larger opening and it popped right off with the 3 inch puller.
Old Apr 28, 2007 | 07:05 PM
Tom454's Avatar
Tom454
Cool Beans.
To Steering Valve Removal again
