Missing Timing Marks
Old Apr 28, 2007 | 08:10 PM
Disco_Mike's Avatar
Disco_Mike
Default Missing Timing Marks
Finally went to set the ignition timing today!
Timing marks are missing.
Where are they attached?
Old Apr 28, 2007 | 10:06 PM
7T1vette's Avatar
7T1vette
They are behind the flamblaster, and just in front of the haglemorph.
[Sorry, I couldn't resist.] The TDC (top dead center) timing mark for the #1 cylinder is on the harmonic balancer (one axial line somewhere on the O.D.) and the "scale" for it is attached to the block just above the balancer at about the 2 o'clock position [as you are looking at it from the front].
Old Apr 28, 2007 | 10:12 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
do you mean the timing index is missing?
here it is
[IMG][/IMG]
Old Apr 29, 2007 | 09:33 AM
Disco_Mike's Avatar
Disco_Mike
Yes the index is missing.
Looks like it is bolted to the timing chain cover.
I cant even see if it is broke off.
Old Apr 29, 2007 | 08:16 PM
bobs77vet's Avatar
bobs77vet
you can buy them and they simply bolt on using two timing chain cover bolts....go to Summit or Jegs
Old Apr 29, 2007 | 10:45 PM
jlaw68's Avatar
jlaw68
here it is
[IMG][/IMG]
i thought the same thing but then i had to replace my water pump i found out that mine was tacked on to the timing chain cover and you can barely see it between the timing chain cover and the backside of the water pump
Old Apr 30, 2007 | 10:03 AM
Poppa Bud's Avatar
Poppa Bud
Cruise-In IX Veteran
St. Jude Donor '08 thru '13
Mine was missing too, got one at AutoZone, about $5, chrome too!
One problem when installing - the lower (iirc) bolt won't come out all the way because it hits the balancer. I cut the lower bolt hole on the timing tab to make a slot and slid it under the bolt head. The other bolt comes out fine.
Old Apr 30, 2007 | 02:08 PM
bobs77vet's Avatar
bobs77vet
i like that soloution
To Missing Timing Marks
