tach wire
Old May 17, 2007 | 08:32 PM
gldnkngt's Avatar
gldnkngt
Originally Posted by hunt4cleanair
Your saying the circuit board is filled with a damping oil?
In regards to the meter pointer, if it goes to zero, than the circuit is broken and therefore circuit board bad?
Not the circuit board, the meter head itself. And when you connect power and ground it should go to zero. If it does not then the board is possibly bad.
