tach wire
Old Apr 29, 2007 | 02:18 AM
blhaley91's Avatar
blhaley91
Navigator
Default tach wire
81 Vette mostly original. My tach wire that comes out from the dist. is not plugged in. I cant find a matching plug under the hood anywhere. It appears to be a yellow or white wire (cant tell) Can somebody tell me where this thing is supposed to plug into?
Great site!
Thanks for the help.
Brian
Old Apr 29, 2007 | 09:53 AM
Duke94's Avatar
Duke94
On my 78', there is a white wire that comes from the "Tach" connection on the dist cap and goes through the firewall and connects to the tach somewhere under the dash. I would think an 81' is the same.
Old Apr 29, 2007 | 10:24 AM
Paul L's Avatar
Paul L
Is your tach working?
Old Apr 29, 2007 | 12:50 PM
TimAT's Avatar
TimAT
SOme cars had a Tach filter- looks like a condenser, mounted somewhere around the disty. Could be on the engine or the firewall, but would, in either case, be within reach of your Tach wire coming from the disty..
Old Apr 29, 2007 | 02:31 PM
SEVNT6's Avatar
SEVNT6
On mine the dist tach wire is soldered right to the filter mounted on the intake. The wire off the filter then has a connector to another that goes on thru the firewall. Mine's original too......
Old Apr 29, 2007 | 02:37 PM
Paul L's Avatar
Paul L
Here is the tach filter but that is an old pic and I can't remember the wiring setup.
Old Apr 29, 2007 | 03:58 PM
blhaley91's Avatar
blhaley91
Navigator
yes this wire does have the filter attatched but it isnt mounted to anything. No my tach doesnt work right now.
So this wire should go into the firewall and plug into the tach?
Actually there are 2 wires coming out of the dist on the tach side. both have the same female connection and arent pluged into anything. One has the filter and is 15 inches long. THe other has no filter and is only 3 inches long???
THanks
BH
Old Apr 29, 2007 | 10:07 PM
Big2Bird's Avatar
Big2Bird
THanks
BH
On an 81, the tach filter is mounted on the EGR solenoid bracket between the two solenoids. The wire coming off the distributor that is short is a test lead. It just hangs there for underhood tach readings. Follow the other lead to the filter, then from there, to the firewall. The wire is white. I can post pics if you need them.
Old Apr 30, 2007 | 01:32 AM
blhaley91's Avatar
blhaley91
Navigator
Ok I found where the wires plug together, but when I plug them in the tach bottoms out. So I guess my tach or circuit board need to be replaced???
BH
Old Apr 30, 2007 | 09:03 AM
Big2Bird's Avatar
Big2Bird
BH
Try bypassing the tach filter first. If it still does it, yes.
Old Apr 30, 2007 | 11:07 AM
gldnkngt's Avatar
gldnkngt
Quite often those tach filters went bad. That's possibly why yours was disconnected. Bypassing the filter frequently solved th problem
Old May 1, 2007 | 02:14 AM
hunt4cleanair's Avatar
hunt4cleanair
That's what filter looks like on my 78 4 speed car. Automatics had a different filter which probably could be confirmed by the AIM.
Old May 1, 2007 | 09:24 AM
Big2Bird's Avatar
Big2Bird
I don't think so.
Old May 2, 2007 | 03:44 AM
hunt4cleanair
Tach on my 78 is not working so following the thread here. Schematic shows the white from distributor going through a couple of connector blocks and onto the printed board of the tach.
Pink wire connects to the tach directly and than the white lead connects to a brown lead which routes through the filter and onto the white wire. Leads coming out of the filter are brown. I'll try dropping the filter out of the circuit as described above.
Old May 2, 2007 | 10:51 PM
blhaley91's Avatar
blhaley91
Navigator
Still no dice. I guess I need to replace the circuit board. When I plug the wires into each other the Tach pegs out. If I unplug it the tach eventually just wanders around with no change when the RPM's change. might go up, might go down, might peg out.
Thanks for the help
BH
Old May 9, 2007 | 03:54 AM
hunt4cleanair
I got around to doing a bypass on the tach filter but tach failed to register a tic. What's next to check?
Old May 9, 2007 | 11:11 AM
gldnkngt's Avatar
gldnkngt
Sounds like it may be the tach board. If you get the tach out, (the whole cluster does not need to come out) Just use care not to scratch up the housing because it's a pain to fix the scratches. On the back of the board are 6 screws. The top 3 are labeled. Connect 12 volts to the screw marked 12v, and ground to the one marked g. The pointer should go to zero. If it doesn't, that's a good indication the board is bad. It'll also give you a chance to inspect the board visually for any indications of burnt ares.
These are also liquid filled with a damping oil. Oftentimes the oil dries out and they act erratically, and need to be re-damped.
To tach wire
Old May 10, 2007 | 05:09 AM
hunt4cleanair
Your saying the circuit board is filled with a damping oil?
In regards to the meter pointer, if it goes to zero, than the circuit is broken and therefore circuit board bad?
Old May 10, 2007 | 08:05 AM
BKarol's Avatar
BKarol
A link for the circuit board replacement. gldnkngt referred to the 6 screws on the back.
http://www.corvettemagazine.com/2005...ch/tach-01.asp
Old May 10, 2007 | 05:47 PM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
When these boards do fail, it is often one of a couple components and many times can be repaired. I've fixed several of them. If I can offer any assistance, please pm me.
Good Luck!
