Remove this solonoid ?
Old Apr 29, 2007 | 09:28 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default Remove this solonoid ?
See the solonoid with the light green vacuum conector? I know it has something to do with ignition timing and engine temp. It is wired up to a 2 prong temp switch on the passenger side head. Does it do anything worthwhile.....?
I am finishing up a total rebuild....74 / 454....remove or re-install ????
Old Apr 29, 2007 | 09:37 PM
Big2Bird's Avatar
Big2Bird
If you want performance, take it off, and run manifold vacuum for your advance. It's a crude, early smog device.
Old Apr 29, 2007 | 09:52 PM
SIXFOOTER's Avatar
SIXFOOTER
Yea I think that was put in there to delay timing advance until the engine got up to operating temp. You can delete it and all its periferals
Old Apr 29, 2007 | 10:17 PM
fotyfobravo
Thanks guys ... I figured it was some 70's FED high tech...
And by the way, Big2 Bird....
your hair (avatar) looks especially nice today!
Old Apr 29, 2007 | 11:09 PM
Big2Bird's Avatar
Big2Bird
Thanks. I am a new, calmer, wiser Bird. Is that a Birdwiser?
Old Apr 29, 2007 | 11:16 PM
7T1vette's Avatar
7T1vette
That unit looks surprisingly like the wiper door solenoid/switch which [normally] resides behind the tachometer.
Old Apr 29, 2007 | 11:25 PM
big_G's Avatar
big_G
Save the parts you take off. They are worth $$$$. NCRS guys go bonkers over finding one of those.....
Old Apr 29, 2007 | 11:40 PM
Big2Bird's Avatar
Big2Bird
Yep. Save it.
To Remove this solonoid ?
