Metal "Tapping" sound? uh oh...
NOW UPDATED WITH PICTURES BELOW:
RECENTLY UPDATED WITH FREE HAPPY ENDING INCLUDED!
I got home just fine. But, the motor seems to be @ 75%
I re-tightened all the header bolts to the heads and still, metal clapping/tapping sound. Grrrreat. My wife & I just bought a new piece of property earlier today and we're trying to figure out who to build our new house, two small babies at home (I can't start the engine now because I'll wake them up
) and the engine is gettin' all goofy now...I could feel air coming out of the area of the head/exhaust header area, but the headers are bolted super tight. I suspect perhaps the header flange is either warped or I have a crack? Or a blown head gasket???
D@mn...A little too busy with life right now to be tearing the engine apart. Looks like the car cover is coming out & time to disconnect the battery for a few months.....Sadly, just in-time for summer
I'll post findings.
Andy
You got it.
Here's what it looks like:
But wait...
Here's what it REALLY looked like...
KaPOW!!! Look closely, the burned area have been charred and burnt for quite awhile....
Does anyone know of a better manufacturer for header gaskets?
Will I need to apply some type of gasket sealant?
Andy
Yikes! This is what I was fearing. I'll replace the header gasket & check plugs first. After that I am going to use your technique to iron out all possibilities.....D@MN! The motor only has 7,000 miles on it
PS- my gaskets looked worse than that!
I have continuously developed an exhaust leak due to the header gasket cracking between the two centre ports on the left bank.
thanks for the tip.
Unplugged the battery, tore out the alternator, took the valve covers off, removed spark plugs.
I did a quick inspection of the plugs= they looked great all nice light tan & clean (like campfire marshmallows when they're ready!
).I then hooked the battery back up & turned the engine over to verify that the rockers & valve train was working as supposed to. Yep. They were all popping up and down happily. Checked the valve clearance w/ feeler gauge. All normal & perfect tolerance.
So the internal componants of the engine seem to be chugging along as required by internal combustion standards
After talking to the good people at Stans Headers (in Auburn WA) I was happily instructed to simply apply a very, very thin coat of Hi-Temp Red Permatex gasket sealant onto both sides of the gasket & re-install the header to the engine. I did that & tightened the headers nice & snug. Hooked up the alternator & hopefully didn't over tighten the alternator belt.
I am always curious as to what is "too tight" or "too lose." But, that's another story...Took the car out for a speed run for about 20 miles. Pulled off an exit ramp in the Columbia River Gorge. Sat on the ramp & stomped on the gas & roasted the tires for 60 yards. Hopped out of the car with my flashlight to check for any oddities..."HOLY SH%T, there was a motorcycle cop right there just 50 feet away from me
" I was certain he was going to ride over & give me an exhibition ticket right then & there. But, he didn't. Probably figured "what in the hell is an old corvette doing way the hell out here, hood open w/ a flashlight doing?" Thankfully, he just tore off down the ramp to probably snag a speeder.
WHEW!Got, home & re-tightened the header bolts, which I am happy to have done as they had already losened up a little.
Stans also encouraged me to check & re-check the bolts over the next 3 weeks. After that, I'll never have to check them again for 20 to 30 years (on average).
Happy ending!
Andy
Wade
