Ride Height
Old May 1, 2007 | 01:04 PM
Vettevice's Avatar
Vettevice
Default Ride Height
I am new to corvettes and was told I can adjust the rear ride height of my car pretty easily. Does anyone have any direction on this?
Old May 1, 2007 | 01:19 PM
kayosnes's Avatar
kayosnes
Adjust the bolts at the outer end of the spring, so that less treads shows. If you cant lower it enough that way. You can change the stock 8"bolt, to a 10"bolt.
I can recomend van-steel for parts like that.
Old May 1, 2007 | 01:26 PM
Godfathers Ghost's Avatar
Godfathers Ghost
You can change it by adjusting the spring bolts. These are the bolts at the end of the spring conecting to the control arms. Tighten them to raise r.h. loosen or use longer bolts to lower r.h. This changes suspension geometry so, for one, you have to have the car alined after, and secondly, don't go too far because any change also effects the various linkage geometry, meaning even after an alinement(which only effects static wheel position) the suspension's geometry is now changed and compromised, so weird things can happen while actually driving.
Old May 1, 2007 | 01:39 PM
Vettevice's Avatar
Vettevice
Thanks. I am looking to lower it a bit. The previous owner has the car sitting a bit high in the rear. Can I do this without lifting the car?
Old May 1, 2007 | 01:50 PM
Godfathers Ghost
Yes, you will have to raise it, not only for better access, but to take pressure off the spring bolts. You will may have to jack the spring itself also, put a C-clamp or large vise-grip on it to keep the jack pad from sliding up the spring.
Old May 1, 2007 | 03:50 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
My guess is that your going to need 8" bolts. The stock 6" bolts only have a little bit of threads on the bottom of the bolts.
Bolts only
http://www.vansteel.com/index.cfm?fu...p=1502&ID=1670
Bolts and cushions
http://www.vansteel.com/index.cfm?fu...p=1502&ID=1676
Use code DD1002
Dan
Old May 3, 2007 | 01:45 AM
OzzyTom's Avatar
OzzyTom
Be cautious of some cheaper after-market long bolts for lowering the rear.
A couple of club members here in Oz had issues with the bolts shearing due to inferior quality. In both cases, luckily they were not travelling fast and only gouged the bitumen as they pulled to the side of the road. At higher speed, could have completely lost control.
To Ride Height
