Are C3 handbrakes useless ??
The tester was starting to get really pi$$ed off at the thought of having to walk back to work & it ended up with me wrenching up on the lever while he was hitting the release button. Eventually it released & I got my MoT pass.During the winter I took it all apart (as it'll never pass this year) & found newish shoes in there & new brake discs (rotors) but with the inside completely worn out ie. somebody had fitted new ones & had either driven with the park brake on, or had badly adjusted it. I fitted new discs (made in China
) & shoes, adjusted it all & it seems to work OK, though I've not driven it as there's no tax or MoT on it at the moment. The manual says to run at 50mph & pull it on for 30secs (or something like that) to bed the shoes in, so I'll do that on the way to the MoT. I'm hoping that it's OK by the time I've driven the 3 miles to the test centre
Having had it all apart, it looks to me like the design of drum brakes on 50's & 60's bikes, in that they work OKish if everything is adjusted correctly & in good condition, but if something is slightly out of spec, or worn, they're nothing less than a POS. When adjusting the shoes you must disconnect the shaft from the wheel to allow it to turn freely. Then you know that you've got the correct adjustment & there's no risk of failing an MoT, or wrecking a new rotor.
This is an emergency brake, not a parking brake and it really works, even at 30 mph it hauls the car down.
If in a safety inspection it is tested it works great but what would happen if I relied on it for hours or days at a time? It might leak down.
It sure beats the rock I used to keep on the floorboard to put behind a tire...
And Norval, that is yet another cool upgrade, where do you come up with these great ideas?
And as to the cupholder? Best upgrade I ever bought for my Vette...seriously! It is a PITA shifting a manual trying to hold a 44 oz. cup of Coke between your knees. I spilled one once time approaching an intersection and skidded halfway into an intersection right in front of one of the local police lieghtenants. Got lucky, he just scowled at me and kept going.
Mandatory Parking Brake Burnishing Procedure:
1) with car on test rolls and rear wheels driven at 50 MPH, apply parking brake until light drag is felt (10-12 notches on handle).
2) operate for 55-60 seconds.
3) return brake handle to released position.
http://www.corvettemagazine.com/2005...brake-lead.asp
So me and my dad were working on my parking brake last week. Since i live in Texas, i figure there is no need for it seeing there arent any mountains or even hills. I did hear a rumor the other day that it has to work to pass inspection. Old cars in TX have to pass the safety part of the inspection. Does anyone know if in TX your parking brake has to work to pass inspection? because if not i wont mess with the pointless thing anymore...
http://www.sportys.com/acb/showdetl....product_id=950
So what your saying is that i might get lucky and they might not test it?
