Hood Insulation Question
Old May 1, 2007 | 04:25 PM
tylershamilton's Avatar
tylershamilton
Default Hood Insulation Question
The Hood Insulation is missing on my 73 and I read in a magazine that said missing insulation can cause the paint finish to get messed up because of the engine heat. Is this true?
Old May 1, 2007 | 04:31 PM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
Funny,,because my car is painted with the same paint as the engine,,just different color...lololl
Old May 1, 2007 | 08:43 PM
croaker's Avatar
croaker
Mid America has one for 45 bucks not oem but looks decent
Old May 1, 2007 | 09:25 PM
GUSTO14's Avatar
GUSTO14
I have seen many of these Corvettes over the years without insulation and few, if any, with paint issues that were directly related to engine heat. It is certainly a possibility, and no doubt has occurred, but it is by no means a sure thing.
Having said all of that, I do have the insulator on the underside of my 73's hood. I'm certain that it provides some heat insulation to the underside of the hood, but I'd bet it provides even more sound insulation than anything else. On the other hand, if it's covered with grease or other flammable liquids, it could easily be more of a liability than an asset, in which case you're probably better off without it.
As previously mentioned, non-original replacements are available at bargain prices and original style ones are also available. If you've seen the non-original replacements, the first thing that will come to mind is how easy it would be to make your own if you can get some of the material.
Good luck... GUSTO
Old May 1, 2007 | 10:30 PM
SEVNT6's Avatar
SEVNT6
I took my hood insulation off around 1980 and it has never affected my paint........which is still original....
Old May 2, 2007 | 12:24 AM
ikesterx's Avatar
ikesterx
No, I have an 80 that never had hood insulation. I have terribly high heat under the hood (stock ram horn exhaust manifolds) and have never had hood paint issues.
To Hood Insulation Question
