A.I.R pump
Old May 2, 2007 | 03:39 AM
tomard's Avatar
tomard
Default A.I.R pump
Since I do not need to smog my 80 anymore in Georgia, I was told by a buddy of mine (also a vette owner in AZ), that some people just cut the belt that goes to the pump and leave it all in place without a belt.
My question is, how much does that improve performance and is it worth even thinking about doing? Are there other things that should also be removed/modified to increase performance when doing it?
Old May 2, 2007 | 07:38 AM
MN80Vette's Avatar
MN80Vette
I don't think it is a simple as cutting the belt. You really should disconnect/remove all the plumbing that goes with it and plug all the fittings if your emissions system isn't working. Anything connected to the crankshaft pulley is going to suck power, but I don't know how much.
I don't have any emissions equipment on my GM 350 HO, but it has Vortec heads, and they burn pretty clean.
Old May 2, 2007 | 08:02 AM
SIXFOOTER's Avatar
SIXFOOTER
You can in fact delete the AIR pump and yes cutting the belt would effectively do that, but that is a very bubba way to do things.
A better way: Remove the entire pump, its hoses, diverter valve and control lines and brackets. This will require a new shorter bolt in the waterpump. You will be chocked at how much it clears up the engine bay. Either cap the air injection tube holes in the manifolds or replace them with headers.
Performance improvement? A little, it will not shave 4 secs off your ET.
The pump uses about 5 to 7 hp at cruise IIRC.
Old May 2, 2007 | 09:00 AM
stingr69's Avatar
stingr69
Not worth the hassle IMHO to mess with the AIR pump unless you get afterfiring when you back off the gas. That is one issue you can experience especialy if the diverter valve is shot.
Pulling the cat off IS worth the trouble.
-Mark.
Old May 2, 2007 | 09:13 AM
SIXFOOTER's Avatar
SIXFOOTER
True, the AIR pump is there to support the cat and with the air pump gone the cat will no longer work well any way.
Just annother reason to go to Duals!
Old May 2, 2007 | 12:23 PM
Darrel1's Avatar
Darrel1
I pulled my AIR system- did not take long to get it all off and yes it does clear up the engine bay alot!!
Darrel1
Old May 2, 2007 | 12:32 PM
fauxrs2's Avatar
fauxrs2
I would be really surprised if the AIR pump took as much as 5 hp to turn, in any case the effect on performance is going to be negligable. The engine bay will certainly look less cluttered but thats about the limit of benefits you will detect removing the AIR system.
If you are still using the factory Catalytic convertor then there is a fair amount of benefit to be had removing that. if you have a high flow convertor then the benefit is reduced.
Old May 2, 2007 | 01:48 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
That little pump takes less than 5 HP probbably half that. The biggest issue you have is that your car is electronic...its' not as easy to just disconnect one (MAJOR) component of the emissions system ... you will have an overheated CAT and check engine light on for sure.
Old May 2, 2007 | 06:30 PM
flood's Avatar
flood
My A.I.R pump was disconnected because it made noise. I couldn't stand it.
If I sprayed it with water, it would stop until it dried out again.
Old May 3, 2007 | 06:01 PM
Joes80's Avatar
Joes80
What is the issue? Will it effect the performance of the vehicle with stock carb, intake etc. just curious. Or are you saying to remove the whole component instead of part and will that effect the the performance? If you take out the cat should you just take out the AIR? Just curious.
To A.I.R pump
