Choke Light?
Old May 3, 2007 | 09:18 PM
ETM's Avatar
ETM
Default Choke Light?
I was driving to work this morning when my choke light came on with a slight buzzing noise from under the console.Sounded like there was a bumble bee in there.
My volts were normal....everything worked as normal.I checked my connection at the alternator,checked the battery connection.Both were good.
Any ideas on what might cause this...or where I could check next?
Thanks Brian.
Old May 3, 2007 | 10:18 PM
kona's Avatar
kona
Not sure what caused it but there is a choke relay under your console. Mine did the same thing I replaced it and everything was back to normal.
Kona
Old May 3, 2007 | 11:16 PM
SIXFOOTER's Avatar
SIXFOOTER
Check the choke heater fuse, if it opens the choke rlay will pickup and turn on the light
Old May 4, 2007 | 08:06 AM
surgn's Avatar
surgn
Also try to have the alternator tested- you could have it all bolted down tight, but it could still be bad... your battery will make you think it's ok, b/c of the voltage meter, but soon it is going to die on you. I know- it happened to me damnit.
Oh yeah- and the choke light was on and making the same buzzing sound which you speak of... I replaced the alternator and it cured the problem. Good luck.
Old May 4, 2007 | 12:42 PM
SIXFOOTER's Avatar
SIXFOOTER
Thats true, if the diode trio grounds it will turn on the light and pick up the relay making it buzz
Old May 7, 2007 | 05:24 PM
surgn's Avatar
surgn
So has the problem been fixed?
To Choke Light?
