Tremec 6 speed?
Old May 5, 2007 | 07:30 AM
cajos's Avatar
cajos
Default Tremec 6 speed?
Would a Tremec 6 speed from a 2002 Corvette Z06 require large modifications when it will be in a 72 BB. Besides the obvious, do I need to alter the tunnel, drive shaft etc.
Old May 5, 2007 | 08:56 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Will not work. T-56's from Vettes mount on the axle in the back. It would be easier to just cut your body off and glue it to a C-5 frame.
Old May 5, 2007 | 09:34 AM
international blue's Avatar
international blue
Try the Richmond 6 speed or 5 speed. The mods are minimal, fits in the tunnel and is a tough transmission.
Old May 5, 2007 | 11:05 AM
shafrs3's Avatar
shafrs3
Or find a T56 from a Viper.
Old May 5, 2007 | 11:13 AM
Corv3tt3's Avatar
Corv3tt3
You could do it but you will need an aftermarket frame like this and you will need to cut out the storage compartment. A t56 out of a camaro or gto would fit though.
Old May 5, 2007 | 06:20 PM
cajos's Avatar
cajos
Thanks guys,
I had a feeling it would not work.
Old May 6, 2007 | 12:57 AM
jeffro1234's Avatar
jeffro1234
or get a T56 from a late model camaro and install that. Its the best upgrade Ive ever done. Only prob is I havent decided how I am going to get my speedo working again since the T56 is designed for an electronic speedo.
Old May 6, 2007 | 03:06 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Buy a Cable-X box. Or an electronic speedo.
To Tremec 6 speed?
