Fresh 383 not running right!
Old May 5, 2007 | 09:14 AM
JW714's Avatar
JW714
Default Fresh 383 not running right!
Just got my fresh 383 in and running from a local machine shop.The engine dynoed at 380 hp and 400 ft lbs.After start up I took it for a "ride",and it falls on it's face at startoff.After it gets going it's not as bad with the spitting out the carb and exhaust but on the hyway it feels like it's got a miss.Seems only under a load.I have a dial back and checked the timing all in 35 degrees at 2500 rpm.I tried the original carb 650 holley and it runs the same as the 750 I bought from the dyno guy.I had this engine rebuilt because of wear and it ran real good before the rebuild!It has a hydraulic roller in place of the mechanical flat tappet.If the cam was installed 180 out what would that do? The cam timing should be at 12 o'clock crank and 12 o'clock cam on the sprockets not 12 crank and 6 cam correct?Any idea before I see this guy on monday? Thanks John W................
Old May 5, 2007 | 09:56 AM
oregonsharkman's Avatar
oregonsharkman
The markers should be at 12 o'clock crank and 6 o'clock cam. Seems odd that it "dynoed" fine but runs bad. Have you checked manifold vacuum and fuel pressure?
good luck.
Old May 5, 2007 | 10:50 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
The cam can't be installed 180 degrees out. Remember that the cam rotates once for two rotations of the crank. When you install the cam, you usually do it with the mark on the crank at 12 and the cam at 6 oclock so that you can do it accurately. If you rotate the crank shaft 360 degrees, the crank will be at 12 oclock as well as the cam. This is # 1 cylinder at TDC.
Old May 5, 2007 | 10:53 AM
69vettester's Avatar
69vettester
The timing marks on setup are 12 crank and 6 cam ,like oregon shark said. But the #1plug @TDC fires when the Crank mark is 12 and the Cam Mark is 12. The #6 plug fires when the marks are at 12crank 6cam..confusing Huh. So, turn the Balancer to O deg. open the Dist. cap , the rotor should be pointing to the #1 Terminal, If its Pointing to the #6 terminal your Timing is 180Deg. Off.
Hope this helps
Tom
Old May 5, 2007 | 11:04 AM
tellcom2001's Avatar
tellcom2001
I Had The Same Issue With My Vette Falling On Its Face. It Was A Fuel Issue With My Edelbrock Had To Change Metering Rods And Springs. Then Changed Main Squirter And Accelerator Pump. Seems Good Now But Im Going To Install A Air/fuel Guage To Set Carb
Old May 5, 2007 | 11:21 AM
JW714's Avatar
JW714
Default Re:383
Thanks I undestand the cam timing now,manifold vacuum at 14-15,fuel pressure at 8 psi.Tried three different carbs all the same outcome.Checked compression 210 psi all cylinders.So internally it should be ok?Has to be carb related?
Old May 5, 2007 | 12:03 PM
69vettester
If your dist. gear is on the right cam gear tooth , and is within Ballpark range, Idling right with reasonable standing throttle response, then Most probably your carb Is crapped out for some reason. I just went through this with a Brand new Carb that had been sitting on the shelf to Long and Had deteriorated.
Take it apart, inspect all parts carefully , especially the gaskets and seals , the Floats needle and seats(make sure the float will float too).
Replace any suspect diaphrams and parts. Put it back togeather and you will be able to dial it in correctly.
Good Luck..
Old May 5, 2007 | 01:02 PM
zwede's Avatar
zwede
Every now and then there are needle&seats that will work perfectly at 6 PSI but leak at 8 PSI. Since it ran fine on the dyno my first step would be a regulator and set it at 6 PSI.
The other thing to check is that you have good voltage to the distributor.
Old May 5, 2007 | 03:50 PM
JW714's Avatar
JW714
Default Re:383
I have 12.8 VDC at the Batt. terminal on my H.E.I. distributer.Guess I'll try a new carb.....Thanks John W................
Old May 6, 2007 | 05:55 PM
JW714's Avatar
JW714
Default RE:383 not running right
I changed the carb to no avail.I then advanced the timing and it ran better and by advancing it untill it's off the scale it seems to run good.Did the dampner slip?How can I tell for sure where the timing is?Any ideas? Thanks...John W
Old May 6, 2007 | 06:13 PM
7of69's Avatar
7of69
If you advance it to far it will be hard to start but seem to run well. So if it's starting without a problem (turning over slow) you may be on to something.
Old May 6, 2007 | 07:33 PM
JW714's Avatar
JW714
Default Re:383
I just got back from a ride and it runs awesome! But now how do I set timing?Do I need to replace the dampner?When I road tested it it pulled real strong and no pinging even pulling 1500 rpms in 4th gear.Plus it spins over with no problem even when hot.Makes me believe the timing is the problem,what if the cam was off a tooth?Would that put the timing mark off the scale?.....Thanks John W.......
Old May 6, 2007 | 09:34 PM
LB66383's Avatar
LB66383
If the cam was off by a tooth, it'd barely run, if at all. The best way to check the balancer TDC is to get a dial indicator with a magnetic base. Pull the #1 spark plug, and use the indicator to measure exactly when the #1 piston is at TDC as you turn over the enigine by hand. Then check the timing marks on the balancer. Have you thought about borrowing a buddy's timing light just in case there's a problem with yours?
Old May 6, 2007 | 09:41 PM
wiseman79's Avatar
wiseman79
You could be using the wrong timing tab. The damper is marked to use with either a tab that is at the 12 O'clock position over the damper, or at about the 2 O'clock position. You may be using the wrong tab which would throw you off. This is an easy fix.
Old May 7, 2007 | 06:46 AM
JW714's Avatar
JW714
Default Re:383
The timing tab is at 2 o'clock but even with it at 12 it still would be off the tab,,,,,any ideas?What would happen if the cam was off a tooth or more?.......Thanks...John W........
Old May 7, 2007 | 04:38 PM
JW714's Avatar
JW714
Default Re: 383
I checked the timing with another lite same as mine.I'm ordering a new dampner.Will let you know.......John
Old May 7, 2007 | 10:02 PM
wiseman79's Avatar
wiseman79
Are you disconnecting the vacuum advance when you check timing?
To Fresh 383 not running right!
