Dynamat / Fatmat installation tips needed
My question is: are there any tricks that make fitment of this stuff any easier? I want it to come out as close to perfect as possible but, with all of the curves and dips in the floor, I was wondering what the best method would be to fit the pieces in the car.
Thanks,
Dave
I was thinking about getting some large sheets of poster board and making templates before I cut into the Fatmat, anyone use that method?
I didnt cut templates, although that would have probably made it easier. The C3 interior is pretty simple. I covered all the flat parts i could then worked on the tunnel and other curved areas.
I used three bulk packs so I didn't have to sweat measuring every inch, worked front to back, and pretty much used the old eyeball to gauge placement. Obvious flat areas were easy, working around the tunnel and dash areas I used smaller easier to manage strips. Like Mike says, use that roller and mash out those bubbles.
#2 once cut and laid down use a heat gun to warm it and then roll it down. makes the stuff super super sticky and form easier to the floor curves
#3 buy some aluminum duct seam seal tape on all the seams
#4 use a nice sharp razor to cut the product.
