Does anybody know...
Old May 5, 2007 | 04:00 PM
BB72's Avatar
BB72
Default Finished pipes
On BB side pipe headers, how do you tell if they are NOS or not. There's no name brand on them, they have never been on a car and you can see they have been sitting around for many years. They were listed as NOS late 60's. On the header flange at the head there is a # 946 or 649 something...thanks...
Old May 5, 2007 | 04:21 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
If you mean by NOS that were they GM parts, no. The only headers that came on a c-3 corvette were some off road headers onto side pipes, similar to hookers but made by someone else at the time. They were all black, never chrome. These may have been a 69 only option and available with the L-88 option. Anything else may be New and Old, But not from GM stock.
Old May 5, 2007 | 04:28 PM
BB72's Avatar
BB72
Default here's some pics
Old May 5, 2007 | 04:31 PM
BB72's Avatar
BB72
Default I've been searching the net
I can't find anything on the net. Anyway of telling what they are?
Old May 5, 2007 | 04:32 PM
c69vete's Avatar
c69vete
St. Jude Donor '07
Those are the style I was refering to as the off road exhaust. Not sure how to tell if they are NOS. THe only info I have is they would have a GM part no on the packaging when they were new.
Old May 6, 2007 | 01:06 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Look like a well worn set of Hookers with 2 1/8 primaries and 4" collectors. I've got two sets of them.
Can't recall the name of the original racing headers, but they had a slightly different twist in the bundle ahead of the collector.
Not my car (wish it were), but here's what they should look like...
Old May 6, 2007 | 01:50 AM
international blue's Avatar
international blue
The off road sidepipes were created for the 66-67 L-88 racers and were handmade initially before being manufactured by the Kustom for Chevrolet. These were equipped with Chevrolet part numbers stamped into the Header flange, a 7 digit number, with another 4 digit number under that number. The headers were offered with the car at delivery at the dealer or over the counter at the dealer. It is unclear how many sets were made. Eventually the Hooker Header company got its start making better than "Kustom" headers and making thousands of sets...
Visually the tubes route different. Regardless of the stampings, the routing of the tubes is different. I have a couple sets of Hookers and a Kustom set as well. I actually think your picture is of a hooker type set, but am not sure.
Old May 6, 2007 | 06:40 AM
BB72's Avatar
BB72
There's only one 3 digit number I can find on the head bolt plate. These aren't worn at all. The have no marks other than the surface rust(no pitting) and the flaking of the original paint. There's no marks on where they are bolted to the head. They're made of heavy gauge steel. Just curious if they actually were NOS.
Old May 6, 2007 | 05:09 PM
TheSkunkWorks
Originally Posted by BB72
The set below are some Hookers I dug out for comparrison. Not identical, but suspect yours are most likely an old vintage set of these, as I believe the bundle on the Kustom pipes is distinctly different. (I'll post a photo of the Kustom's if I can find it.)
Old May 6, 2007 | 05:51 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Pictured is a set of early Hooker Sidemounts on the left and a Set of GM (Kustom) factory headers on the right. They are stamped with 3960710 & 3960709. You can see the difference in the pipe routing. The GM set are said to provide excellent clearance for starter, frame, steering box etc. The downside if you want to call it that is the GM sidepipes primaries don't appear to be equal length. I'm not sure how big a difference that would make.
Your set appear to be similar to the Hooker sidemounts.
I have a set of both.
Old May 6, 2007 | 06:01 PM
BB72's Avatar
BB72
Originally Posted by Jughead
Pictured is a set of early Hooker Sidemounts on the left and a Set of GM (Kustom) factory headers on the left. They are stamped with 3960710 & 3960709. You can see the difference in the pipe routing. The GM set are said to provide excellent clearance for starter, frame, steering box etc. The downside if you want to call it that is the GM sidepipes primaries don't appear to be equal length. I'm not sure how big a difference that would make.
Thanks guys, I believe your right, hooker side mounts. No part # or stamps. Thats the comparison I was looking for. I still think I got a deal for never installed dent free headers. They just need cleaning up. I only paid $180 CND for them.
Old May 6, 2007 | 06:48 PM
TheSkunkWorks
...The downside if you want to call it that is the GM sidepipes primaries don't appear to be equal length. I'm not sure how big a difference that would make.
The different length primaries cause different tuning pulse frequencies at the exhaust valve for each cylinder. Evidently it's a significant reason why there are so few sets of Kustoms as compared to the Hookers.
btw... excellent comparison. Couldn't help noticing the difference in how the two makers attached the primaries to the flanges.
...I only paid $180 CND for them.
I think you did real good. What finish are you thinking of having done?
Old May 10, 2007 | 11:51 AM
BB72's Avatar
BB72
Default Here's the finished product.
How does it look? Bead blasted and coated with high heat flat. Anybody got any side tubes and baffles in good shape?
To Does anybody know...
