Lars or other carb gurus.
The only thing that I wonder about is the choke housing adjustment.
I marked where the cover was before I rotated it. The adjusting counter clockwise of the cover allowed the butterfly to close as it is supposed to, that was fine. Its the part in Lars paper that says, "On hot air choke systems, the cover scribe mark should be aligned with the second dot clockwise of the center dot on the choke housing marks", that is different than what it was originally set at. ****I just re-read the previous sentence and actually my setup is different. On my car the cover has one dot on it and the housing has the center scribe mark and three marks on either side of the center mark. So mine is opposite of Lars example...the end results are the same?
To me the way I read it is this: my choke cover, with the one dot on it, should be lined up on the second hash mark over from the center mark on the choke housing unit? Thats how I have set mine up. If its not running right I will just put it back in the position previous to rotating the choke cover.
I adjusted it to where Lars said and will start it up tomorrow morning, its very late now. Its that its about 1/2" off from where the cover was set to where it is now. Before I adjusted the cover the dot wasn't even lined up with any of the marks, it was counterclockwise, which is more lean. So it seems it will be more rich now.
Thanks Lars and others that have helped. The carb is adjusted to specs, so it should be good to go.
I adjusted the choke pull off as the sheet said....its not right obvioulsy. I have not messed with any other carb adjustment other than the regular idle, but that doesn't come into play till car is warm.
I may have to bring to shop for the cold choke adjustment...I don't want to.
The engine is warm and I can shut it off and restart over and over and its fine now.
Jeez.
Also - there is no "dot" on a stock choke cover. There is a scribe line. If you have a dot, you do not have a stock cover for a hot air choke. You can send me the carb if you want me to check it and set it up for you.
Lars
If this is a hot air choke and you don't have a scribe line, set the cover as follows:
With the engine cold (first thing in the morning), loosen the 3 cover attach screws. Rotate the cover a little bit in both directions and verify that rotating the cover causes the choke to open and close. Once verified, rotate the cover counter clockwise until the choke blade fully closes, but not any further. This is the correct starting position for the choke. For adjustment, keep in mind that the choke cover rotational position determines the duration of choke application - not how rich or lean the carb is upon startup. Rich/lean is actually determined by the choke pulloff adjustment. But setting the choke cover to the position where the choke is just barely fully closed will work well for almost all applications. Compare that setting to where your "dot" is located: I'll bet that the dot is probably 45 degrees clockwise from the housing alignment marks...
If this is an electric choke, the dot in the cover is aligned with the forward of the 3 cover hold-down screw/clips.
