side exhuast or under?
Old May 5, 2007 | 11:58 PM
elevatordude's Avatar
elevatordude
Default side exhuast or under?
I'm trying to find out if my vette had side or under exhaust (oem) at this point I know it had both at one time or another.... I'm new
Old May 6, 2007 | 12:19 AM
Solid LT1's Avatar
Solid LT1
Only 69 Vettes came with side exhaust. Pretty hard to document without build sheet.
Old May 7, 2007 | 05:47 PM
elevatordude
mine is a 69 I was trying to find out because I belive in Mass it is illegel unless oem
Old May 7, 2007 | 06:35 PM
StickShiftCorvette's Avatar
StickShiftCorvette
I don't think your state can PROVE your car didn't come with factory side exhaust.
Old May 7, 2007 | 06:57 PM
Mr.Gearhead's Avatar
Mr.Gearhead
I agree... to my expert knowledge, and I will testify for you... all 1969 had sidepipes. Especially those that aren't legal unless they were OEM...
Seriously... there are a few places to check on the car... but NOTHING to prove except the build sheet. You can buy one online, spill some coffee on it... wrinkle it... then show it to DOT.
Old May 7, 2007 | 09:03 PM
elevatordude
thanks gearhead your the man with all the plans ....and thanks to all for the input
Old May 7, 2007 | 09:33 PM
coinwasher's Avatar
coinwasher
Look in the rear storage area written on the inside ceiling you would see N-14 hand written. Look between the frame rails and the body in the area under the doors and you will see some insulation if it was a N-14.
If you want to see all of your options, you can peel back the carpet behind the drivers seat and you will also see handwritten versions of the options on your car. Mine had PW (power windows), PB (power brakes), and N-14 (sidepipes)
To side exhuast or under?
