Please say this will work!!!!
You got any thoughts on this particular case?
I also have dual spals and 4 core to keep temps down w/AC on!
Ricisan
http://forums.corvetteforum.com/show....php?t=1621965
693HP @ 6500 Rpm @ 656 ft lbs @ 4500, 679 ft lbs @ 3000 rpm. Thanks Rich.
(OMG! When blueonblue logs back on, he won't recognize the place, will he?
Blue on Blue if you want us to figure out your numbers we need the Intake valve closing seat closing point, not the @.050 closing.
Engine specs:
383 .030 over
5.7 rods
Pistons: speed pro 12.5 dish
1.6:1 Roller Rockers on Intake Valves 1.5:1 Exhaust
Deck clearance: .025
Heads: World S/R Torquers 67cc Pocket ported and Runners cleaned
Cam Specs Intake Exhaust
Gross valve lift: .470 .470
Duration @
.006 Tappet Lift 270 270
Valve Timing Open Close
@ .050 Intake: 6 BTDC 38 ABDC
Exhaust: 38 BBDC 6 ATDC
These specs are for cam installed
@ 106.0 Intake Center Line
Intake Exhaust
Duration @ .050 224 224
Lobe Lift .3130 .3130
Lobe Seperation 106.0
Hope this helps; Skip
I figured it out with the number you gave with the intake .006 closing at 61 and you are at:
10.5106431866686 static CR
8.6719627742754 Dynamic CR
also your vavle lift on your intake will be at .501 with the 1.6 rockers
I would strongly advise going with aluminum heads or a bigger cam, even if you install your cam at 4* advanced you will still be at 8.42238701318257 DCR. I think you will have problems with pump gas on this set up. Or you can use a thicker bigger bore head gasket like a fel pro but your already at .049 quench so that will put you in the .050's as far quench goes.
Again, I am a novice at this myself, I would check with Motorhead, Jackson or some of the other engine builders on here to see what their opinion is.
Hope this helped.
Skip
INPUT:
Advertised Intake Duration: 273 (added 3 for the 1.6:1 rockers)
Advertised Exhaust Duration: 270
Lobe Seperation: 106
Intake Lobe Centerline: 102
RESULTS:
Seat Timing:
......................Open.............. ................Close
Intake..............34.5 BTDC.......................58.5 ABDC
Exhaust............65 BBDC.......................25 ATDC
Overlap:.....59.5....................... .Total Advance: 4*
I figured 68cc for the head volume since I will remove at least 1cc with polishing, and I intend to check them. With .020 gasket thickness, 4.100 gasket bore, .025 piston to deck clearance, and 12.5 dish pistons; I get:
Static Comp: 8.15722
Dynamic Comp: 9.70433
Quench: .045
Now I am likely to have put something in wrong and maybe you could show me my mistake, but if these figures are correct would it run OK on 93 octane in your opinion?
Thanks again for your input.
INPUT:
RESULTS:
Seat Timing:
Quench: .045
Ok so with the:
I came up with the same seat timing, next we go to the
dynamic stroke length which is 3.08347312177741
piston BDC is 0.6665
bore 4.030
stroke 3.75
head 68cc
gasket bore 4.100
deck clearance .025
piston 12.5 dish
you get:
SCR 9.70433822187498
DCR 8.15722478666967
now with the same numbers with a intake centerline of 106 they are:
DCR 7.93749991637485
the first numbers I gave you were with the .024 thickness and 5cc flat tops
You might be alright if the numbers you gave me were exact but if it were me I wouldn't try it.
now if you retarded the timing 4* with this set up you would get a ICL of 110*
DCR 7.70395103914939
This I think you would be alright with 93 octane and iron heads given all the above numbers were correct.
My DCR is at 7.77208820273557 and I very pleased with the street performance. Also my heads are aluminum so I could have went for more but decided to play it safe. Again this is just my opinion, your best bet would be to call all the manufacturers of your heads, camshaft and pistons and give them all your numbers and see what they come up with. They will know the tolerances of their products combined better then I do, I am just going by the empire net calculator.
Rich
I ran the 270H cam with iron heads and ~10:1cr with no problems on pump gas, I did not run a vaccum advance though
Ricisan
