The Carb Shop
Old May 8, 2007 | 05:32 PM
LannyL81's Avatar
LannyL81
Default The Carb Shop
Anyone have experience with The Carb Shop in Costa Mesa, CA?
Thinking about sending them my E4ME carb and see what they can do with it.
Old May 8, 2007 | 05:45 PM
71white's Avatar
71white
Let me know if they can rebuild it and maintain the gold color.
Old May 8, 2007 | 06:11 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I purchased some parts from them in the past and they seemed to know what they were doing. No rebuilds though.
Old May 8, 2007 | 08:38 PM
Big2Bird's Avatar
Big2Bird
http://www.carbcareusa.com/oem.html
This place does feedback carbs. Look as new when done.
Old May 8, 2007 | 08:39 PM
njcardave's Avatar
njcardave
I sent my carb to BFIC/Carbsonly in Burbank, CA. Talk to Carlos Vasquez, he will ask you for specific details about your cam, intake, and exhaust. My car has never idiled this good. 877-333-3130.
Old May 8, 2007 | 09:09 PM
rklessdriver's Avatar
rklessdriver
I have a few customers who used "The Carb Shop" modified Holleys on their oval track cars back a few years ago.
They were as good as the BG's and Braswells we normally ran back then.
I honestly don't know how good they are with Q-Jets.
Will
Old May 8, 2007 | 09:20 PM
DaveL82's Avatar
DaveL82
The carb shop had a very good reputation for both Holley and Rochester carbs so if it's still the same company they should be able to set you up correctly.
Old May 8, 2007 | 09:31 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Reputation as absolutely top notch carb gurus. Often featured in magazines. Wouldn't hesitate to send them your carb.
Old May 8, 2007 | 09:43 PM
mrvette's Avatar
mrvette
IS it any relationship to the Carb Shop of some years ago that Brad Urban ran in Ontario Cali??? I hears Brad died suddenly....younger guy too boot....sickness...
wonder about that must be state registered trade name....been a long time....
anyone??
Old May 9, 2007 | 12:18 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Sent my Rochester for my 442 to them.
While the finish looked great. and carb was jetted properly for cam and compression. I couldn't believe it when I saw that they installed a piston and metering rods for the primary circuit.
As many would think.. Most carbs get metering rods in the primaries.
But NOT on a 1970 442 W30 4speed car. Those carbs use jets only on the primary side. Carb body isnt drilled for vacuume to pull the piston down. Heck cam is so big the factory didn't put power brakes on the car.
Was dissappointed that a shop with credits in National mags couldn't do a little research on a rare carb
Old May 9, 2007 | 12:31 PM
Kalway's Avatar
Kalway
I believe there's a carburetor shop closer to ya Lanny. One in Mesa, I can't remember the name, though. They seem pretty knowledgable about q-jets.
However the E4ME is one of those carbs no one LIKES to touch.
Old May 9, 2007 | 02:05 PM
Freepop's Avatar
Freepop
Does Lars do those?
Old May 9, 2007 | 02:24 PM
Kalway's Avatar
Kalway
Originally Posted by Freepop
Does Lars do those?
Newp. It's the one q-jet he don't like to touch.
Old May 9, 2007 | 02:47 PM
LannyL81's Avatar
LannyL81
Lars was my first choice.......
I rebuilt this thing....followed the books...everything went together just fine...made all the adjustments.
However on the car (back when it was running) I could turn the idle air mixture screw all the way out....all the way in....no difference, and it was running very rich. Rechecked all the adjustments...tried different settings...but could not improve it. May be one of the primary jet wells is leaking....sure do not see any cracks or fuel puddles....all I know is that something is wrong.
If there is a shop in Phoenix area that can do a good rebuild of this
E4ME...I would sure like to know...
Old May 9, 2007 | 02:51 PM
Kalway's Avatar
Kalway
Sounds like a sensor is failing somewhere outside the carb probably. Checked the O2 sensor or the MAP?
Old May 9, 2007 | 03:07 PM
LannyL81's Avatar
LannyL81
My thinking too....I replaced the O2 sensor...and tried a MAP from a different car....no change.
The idle A/F solenoid was moving, I just could not get the idle air bleed valve to the correct dwell setting...that and it was supposed to only need 1/8 of a turn....I could make multiple turns and not see a difference. If I blip'ed the throttle everytime after making ad adjustment to the idle air bleed valve, I could see a slight change on the dwell meter. But it still required multiple turns to get to the correct dwell...and then if I checked it the next day....totally off.
Something is just not right.
Old May 9, 2007 | 03:38 PM
glen242's Avatar
glen242
Sent the Q-Jet from my '76 to The Carb Shop in Costa Mesa, CA about 6 years ago. They asked for engine specs, etc. It has been trouble free. Runs as smooth as FI once warmed up.
BTW, The Carb Shop in Ontario has a web site. When I was doing my carb, the Ontario shop did not have a very good reputation. Things may have changed.
To The Carb Shop
Old May 9, 2007 | 04:33 PM
Tom454's Avatar
Tom454
I've rebuilt E4ME's before.... they are difficult to set up if anyone has messed with the APT adjustment.
A few tid-bits in here...
http://www.73-87.com/7387garage/drivetrain/myqjet.htm
If a mechanic is not aware of this adjustment, and he simply unscrews it to clean the carb, then there will be problems.
See it happen all the time.
Old May 11, 2007 | 10:08 AM
LannyL81's Avatar
LannyL81
Never heard about this APT. It is not mentioned in the '81 Service Manual nor Doug Roe's book (in the E4ME section anyways).
I ready through the link above..and interesting that I am using the same 268H cam in my '81. May be I will take the carb apart once again and drill-out the holes...may be that is.
The primary metering rods are controlled by the solenoid...and what I am going to try here is move the adjust range of the solenoid so that it is higher on the metering rods...so that its leaner....
I am going to try working on it again before admiting defeat and sending off to The Carb Shop.
Old May 11, 2007 | 11:40 AM
comp's Avatar
comp
Hmmmmmmm
