Replacing Half Shafts?
Old May 8, 2007 | 07:55 PM
Skyhigh82's Avatar
Skyhigh82
Default Replacing Half Shafts?
If I replace the half shafts do I need to realign the rear-end?
Old May 8, 2007 | 08:47 PM
jdmick's Avatar
jdmick
I suppose if they're not the same exact length it could throw off the camber. You're replace the whole shaft and not just the u-joints?
Old May 8, 2007 | 08:52 PM
Skyhigh82's Avatar
Skyhigh82
Replacing the u-joints
Old May 8, 2007 | 08:56 PM
jdmick's Avatar
jdmick
Should be fine. Just keep track of which side you took them off of for when you put them back on in case Bubba installed one of a different length. Doubtful but it's possible.
To Replacing Half Shafts?
