Best electronic distributor.??
Old May 9, 2007 | 12:06 AM
L Holmes's Avatar
L Holmes
Default Best electronic distributor.??
Opinions? Looking for a ready to run or plug & play aftermarket distributor. Not planning on using a CD box at this point but having one that is compatible for future would be nice. Dont have room for the big HEI style cap. Opinions? breakerless magnetic? Unilite mallory? Pertronix pug & play? Etc. I also prefer the old points style cap so I can reuse my existing wires as they are almost new. Going in a high rpm street strip car with old dual points dist. Opinions? pros & cons? thanks
Old May 9, 2007 | 12:53 AM
sperkins's Avatar
sperkins
I think the coolest thing on the market now is MSD's Pro Billet E-curve distributor. You can dial in your mechanical and vacuum advance curve with just a turn of two dials on a micro-processor under the cap. No need to guess at it by changing springs and weights. It also has a built in rev limiter. It comes with a chart showing exactly where to set the dials for different timing curves. It also has a timing retard feature for easier starting if your running high compression. It will crank retard the timing from 5 to 20 degrees. It can't get any easier than that. I'd be running that distributor for sure if I didn't have to have a tach drive unit.
http://store.summitracing.com/partde...5&autoview=sku
Old May 9, 2007 | 02:53 AM
L Holmes's Avatar
L Holmes
HEY I like that one! And wasnt aware it existed.
Old May 9, 2007 | 03:22 AM
Little Mouse's Avatar
Little Mouse
Very nice dist has the dependable magnetic pickup.
Digital E curve MSD-8394, $386.88 you will need male type
plug wires for it.
Old May 9, 2007 | 03:39 AM
L Holmes's Avatar
L Holmes
Mouse: you must be working the night shift like me tonight. I thought I was the only guy who posts at 3 am.
Old May 9, 2007 | 03:48 AM
Little Mouse
Mallory has a lot of distributors with female style caps and the newer
male type. What do you want in a dist, most will require a
cd box and almost 100 percent of MSDs use male plug conection.
Do you want mechanical advance or vacumm. Mallory has some nice
new dists. out and there price tag for both dist. and CD boxes are more
reasonable. The male conections are better if you can afford new wires.
If you buy the nice MSD E-curve you will have around $440.00 in dist
and wires then there is the cost for a cd box you will want and they use
different coils with cds, you could end up with $650.00 or more in parts.
Old May 9, 2007 | 04:15 AM
PNK's Avatar
PNK
No need for a CD box with the MSD -Ecurve
Old May 9, 2007 | 07:35 PM
L Holmes's Avatar
L Holmes
Yeah I was planning on just using the distributor without the CD box initially, but wanted one that could be upgraded with a CD box later if the need was there. Im not sure of the value of the CD box other than rev. control which this dist. has. Pros & cons on CD boxes? I have seen a few guys broke down because of a bad CD box.
Old May 9, 2007 | 07:53 PM
Little Mouse
Gull now has the high tech MSD E-curve, but I believe he put
100,000 miles on a mallory unilite. Pretty sure the unilite is a
stand alone dist can be used with or without a cd, it uses an
optical trigger.
MMA-3748201 is mehanical advance uses female plug wire cap
$229.95, MMA-4748201 is the same dist. but with vacuum adv.
$235.95.
Old May 9, 2007 | 08:02 PM
L Holmes's Avatar
L Holmes
Yeah I have a unilite on my Vette. I works fine I think. Easy to hook up & is stand alone. Not sure if its as good as meg. pickup dist.? I also put a unilite in a 71 GMC 2wd pickup I used to have. Man that was a cool truck! C20 custom with towing package. factory 396 (402) TH400 trans, 4:30 gears, power stearing & power front disc breaks. It survived on a steady diet of mustang GT's
Old May 9, 2007 | 09:34 PM
big_G's Avatar
big_G
Fully self contained, fits (with a little persuasion) under the shielding. Tach. drive, mech. and vacuum advance. Uses your existing ignition wires.
Old May 9, 2007 | 10:30 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Call Performance Distributors and have them custom curve a DUI for your specific application for just $279. It'll plug right in and be right on the money, no guess work. If it's external gadgets you want, move up to their 18volt system.
http://www.performancedistributors.com/
Old May 9, 2007 | 10:32 PM
comp's Avatar
comp
Old May 10, 2007 | 10:06 PM
68 NJConv 454's Avatar
68 NJConv 454
Very nice. Exactly what I will need...if only it were not so pricey.
This is a direct plug in for the vette mech tach? no adapters needed?
Old May 10, 2007 | 10:23 PM
big_G's Avatar
big_G
Yep...Fully plug and play. Only need the $$$$...
Old May 15, 2007 | 02:21 PM
68 NJConv 454
The big question...is it worth it to convert from mech tach to electronic tach?
I've got my stock mech tach gauge but will need a new cable. Don't have a distributor yet so can buy either.
Have read a few threads on the mech tach's wearing themselves down around the cross shaft gears.
But then you have the cool factor of the mech function.
Is it worth to convert the tach gauge to electric and go with an electric distributor??? Performance and longevity in mind.
My research...
http://forums.corvetteforum.com/show...ight=mech+tach
Old May 15, 2007 | 03:21 PM
jackson's Avatar
jackson
Originally Posted by 68 NJConv 454
The big question...is it worth it to convert from mech tach to electronic tach?.....Is it worth to convert the tach gauge to electric and go with an electric distributor??? Performance and longevity in mind.
Don't forget to factor in the time & aggravation involved if you R&I any in-dash tach. Either pricey tach-drive mallory 7564501C ... or asian equivalents at <$200 (check http://www.starperf.com/tabloid/page_86.htm P/N 9200TDR) are a smart choice if you have room for larger, coil-in-cap HEI (most do).
-edit-if you so choose to later ... you can easily bypass the module & run a CD box ... and you can relocate the coil ... works on above mallory, asian or any large cap HEI.
To Best electronic distributor.??
Old May 15, 2007 | 05:27 PM
gkull's Avatar
gkull
I am running this MSD E-courve on my 383 and 434 small blocks. They are made for more street like motors and have **** poor choices on the timing curves, and advance choices. They are not made for after market aluminum heads that use 32 degrees of ignition advance. So they suck for me. I would wait them out for revision 2 or check out the Crane Cams model.
http://www.cranecams.com/?show=brows...27&showAll=yes
I used Mallory Unilite Vac advance dist. for many years. The problem with them is you really need to send it in to them to have it recurved for your needs. It was not a problem for me since they were only 30 minutes away
Old May 15, 2007 | 08:29 PM
11Jake's Avatar
11Jake
I was also looking at the MSD E-Curve but I am now second guessing with the above comments. Some like it and some guys don't. Any other sugestions on other dist.
Old May 16, 2007 | 06:25 AM
Little Mouse
Depends on what your needs are, if you have a high rpm high
comp engine a dist with a cd box would be good. if you have
a pump gas friendly hydraulic cam mid range rpm engine a new
HEI dist can do that job.
