The instrument bezel has been taken out many times over the life of my 69. In doing so the holes inwhich you screw into the left and right dash panels have become enlarged.
If it was wood a toothpick and white glue would do the trick.
What are your methods to tighten the holes so screws will take?
Lowes and Home Depot (and probably others) sell fasteners with sheet-metal type threads on the outside and tapped for machine screws inside. I think these are meant to be screwed into wood, but they work great for the dash panels. By using machine screws, there's no danger of stripping the holes if you have to take it apart again.
This idea came from an old thread a few years ago.
I believe this is what he's talking about...I used these for the very same location as you inquired about. I drilled out hole slightly smaller than outer dimension of these inserts and used clear epoxy on threads when I installed them. So far so good. Be careful though as an undersized hole will cause these inserts to split your plastic....needs to be just slightly smaller.
The "correct" fix would be to fill the holes with a little putty-epoxy and redrill for the correct screw. If you are "Bubba", stick something in the hole to tighten up the screw. An alternative [but not correct] method would be to drill the holes a bit larger and insert small wall anchors for the screws to get a better bite.
The easy fix is epoxy glue called Plastic Fusion, or Plastic Weld. Both can be purchased at Wally World, Auto Zone, Home Depot ect….
It comes in a two part tube and you mix it up! After you mix it up, force it in the hole of the dash pad with a putty knife! Once dry (Over night for the smart people), drill a pilot hole for the screw and then put the console in. You will have a perfect repair.
You will need to force this in the hole and you only have about 5 minutes of working time before this stuff starts to get hard.
This glue works great for repairing any ABS plastic parts including Rear Quarter Trim panels, Dash pad holes, Shift console tabs, Shift console cracks in the under side, and just about any part made of plastic.
It makes a solid bond, and will last you longer than the original hole in the pad did.
